5th Gen: What did you do to your 5th Gen today?
Finally!!!
I finally replaced my heater blower motor after listening to it growl for about two years.The whole job took a whooping 15 minutes!!
Also,I jacked her up and figured out why my exhaust was getting loud(again).Ordered a new muffler.
176,000 miles and still going strong!!!
Over course of 10 days or so...
Nwp 5 piece spacers
Cattman GenIII headers and y
O2 sims
All new spark plugs
New high pressure power steering line
Zeitronix Zt-1 wb w/ Zt-3 gauge
Apexi neo afc
Tuned
Courtesy of Darryl at Pride Auto and Vanku at Vanku Auto Sports!
Will post pics and vids soon
Nwp 5 piece spacers
O2 sims
All new spark plugs
Apexi neo afc
Tuned
Nwp 5 piece spacers
O2 sims
All new spark plugs
Apexi neo afc
Tuned
Nwp 5 piece spacers
O2 sims
All new spark plugs
Apexi neo afc
Tuned
I finally tossed on front rotors. Yikes the braking feel is so nice now.
Mine was the heat shield over the exhaust pipe near the fuel tank.
Replaced a bad O2 sensor which cleared 3 SES codes, no more check engine light, yea! The bad sensor I removed wasn't even the correct sensor for the car, the routing was different and the conncetor under the engine cover was a bit funky. The new Bosh O2 sensor from Rock Auto was an exact fit with all the little zip tie clips in the correct positions.
Been looking for 01 fog lights and finally picked some up at a local junk yard from a 2000 sentra and only cost me $6 for the pair. My maxima did not have fogs and converted it to have fogs, looks much nicer with them rather than the black fog caps.
Replaced the upper intake manifold gasket (felpro), outer tie rods, stabilizer links and bushings (moog), pcv valve, drive belt, got an alignment and fresh oil change with pennzoil platinum and purolator pureone oil and air filters. Took 2 days for everything. NGK iridium plugs done like 2 months ago so my spring tuneup is now complete and the car is running great! But note that I only replaced the UIM gasket because I was chasing that cold start stalling issue that some other members of the org have had. After replacing the MAF and ruling out other possibilities, I was sure it was the gasket. Turns out the gasket was perfect and it was just the pcv valve. So I'm feeling like a dumba** for having spent $200 for replacing the gasket, but I'm glad the car is finally fixed. 2000 maxima gle, 127k
I finally replaced my front rotors and pads. My old set-up (Brembo blanks with Raybestos Quiet Stops) were badly warped, causing very bad judder at high speeds and plenty of noise at low speeds.
I replaced them with PowerStop rotors and pads (http://www.rockauto.com/catalog/more...678&cc=1359222). They are inexpensive (about $150 for all 4 wheels) and so far I am impressed with their quality: no measurable run-out out of the box! This compares very well with the old rotors, where after 60k miles the run-out was an order of magnitude higher than the maxim allowed.
We'll see how they behave over time ....
Nice paint Maverick. Is that original? Looks like some time was spent refinishing to a glassy finish. Is that an Iconic Dynamic rear window spoiler. I have been debating getting one but I haven't decided if it is the right add on for me.
I try and keep the paint looking good, yes thats where i got it from. I personally love the look it gives the car
Drove it again for school/work today but I got used to the cushy ride of the Camry so the Maxima felt bumpy (KYB GR2 with H-tech springs).
Maverick4189 has such a clean car ><
Installed Brand new factory style cat back made by Bosal, no more loud alarm setting off exhaust. my old one was way to loud.so now its the warp speed Y pipe, one cat, that goofy angle piece where the O2 sensor goes, resonator and muffler.
heres what i did since january
119000 replaced 4 tires, pads, rotors, front cv axles
119500 kenwood double din dvd stereo, new serpentine belts
120000 walker soundfx cat back muffler, new oil pan, oil change with synthetic
121000 transmission fluid replacement with synthetic
122000 replaced starter, added a 2nd ground from battery to transmission
122500 added a flush mount usb port and aux input next to shifter
123000 replaced spark plugs, oil change, lubricated window tracks with silicone spray, replaced HVAC control bulbs
123250 replaced trunk lid with SE one that had a spoiler and replaced red tail lights with clear SE style from junkyard donor
123500 leaking cat flange removed and straight pipe welded in, blue LED bulbs in gauges
123750 right downstream o2 sensor (sensor 2 bank 2) replaced with bosch
124000 new idler pulley and tensioner from dealer, replaced dented door rear from junkyard donor, K&N Air Filter, 4 monroe quick struts
124250 new a/c compressor and recharge, new wiper transmission and arms
125000 new radiator and coolant
future plans. adding heated mirrors (68 a pair on amazon), doing big 3 wiring with stinger voltage gauge on terminal, adding another voltage gauge (in place of clock maybe), 03 bumper and hid headlights
