HowTo's: 4th Generation Maxima
4th Generation HowTo Sticky
DO NOT POST IN THIS THREAD
*** DO NOT POST IN THIS THREAD. IF YOU FIND AN ISSUE WITH A LINK OR WANT TO ADD A SUGGESTION, PLEASE PM KEVLO911 or ANOTHER MOD. THANK YOU FOR YOUR COOPERATION. ***
*** Note: To search this thread, use the "Search This Thread" box in the upper right corner. You can also press CTRL + F on your keyboard to open a search box from your web browser. ***
*** Note: It seems like Motorvate.ca is down and the content has been removed. There will be many broken links linking to that site. If you have links for me to replace them with, great, if not...sorry but I can't help in this case. ***
*** Note: If a link is broken, try plugging it into this site first: Link ***
General
HowTo: Read Your VIN# - Link
Interior
HowTo: Change Auto/Digital Climate Control LED's - Link
HowTo: Change Hazard/Rear Defroster LED's - Link
HowTo: Change Ignition Switch - Link - Refer To Posts #45 and #46
HowTo: Always Illuminated Clock - Link
HowTo: Change Instrument Cluster Bulbs - Link
HowTo: Change Manual Climate Control LED's - Link
HowTo: Change The Clock Color - Link
HowTo: Change Window Switch LED's - Link 1 | Link 2 (Rear Switches)
HowTo: Install 2000-2003 Maxima/I35 Seats - Link
HowTo: Install Autometer Gauges - Link
HowTo: Install I30 Auto Dim Rear View Mirror - Link
HowTo: Install Indiglo Gauges - Link
HowTo: Leather Boot Install - Link
HowTo: Maintain/Service Sunroof - Link
HowTo: Make LED Dome Light - Link
HowTo: Make LED Needles - Link
HowTo: Paint Center Console Parts - Link
HowTo: Remove Door Panels - Link
HowTo: Remove Gauge Needles - Link - Steps #8-10
HowTo: Remove Rear Speakers - Link
HowTo: Remove Speedometer - Link
HowTo: Stop Center Panel Squeeks - Link
HowTo: Add AMB (ambient temp) button to 98/99 Climate Control - Link
Exterior
HowTo: Change Head Light Bulb - Link
HowTo: Convert 95-96 (Front/Rear) to 97-99 (Front/Rear)
- Convert Front Bumper: Link 1 | Link 2 | Link 3 | Link 4
- Convert Headlights: Link 1 | Link 2
- Convert Grille: Link
- Convert Rear Bumper: Link 1 | Link 2
HowTo: Create Rear Fog Light - Link
HowTo: Debadge Your Trunk - Link - Post #15
HowTo: Installing A 2001 Mitsubishi Galant Spoiler - Link
HowTo: Install An Ionic Dymanic Body Kit - Link
HowTo: Install LED Strip For Rear License Plate - Link - Bottom of Post #5
HowTo: Make A 95-96 Mesh Grille - Link
HowTo: Make A 97-99 Mesh Grille - Link
HowTo: Make A Flip-Flop Trunk - Link
HowTo: Make All-Red Tail Lights - Link
HowTo: Make Anniversary Edition (AE) Head Lights - Link 1 | Link 2
HowTo: Make Skyline Tail Lights - Link
HowTo: Paint Rims - Link
HowTo: Polish Your Rims - Link
HowTo: Remove And Install Exterior Door Handles - Link
HowTo: Remove Fog Light (95-96) - Link
HowTo: Remove Fog Light (97-99 - Same As 95-96 But Requires Two Bolts To Be Removed) - Link
HowTo: Retrofit HID's Into Stock Housing Without Projectors - Link
HowTo: Retrofit HID Projectors Into The Stock Housing - Link
HowTo: Rewire Bumper Lenses - Link
HowTo: Rewire Bumper Side Marker To Blink - Link
HowTo: Rewire Fog Lights To Work Independently - Link 1 | Link 2
HowTo: Smoke Corner/Signal Lights - Link
HowTo: Tint Tail Lights - Link 1 | Link 2
HowTo: License Plate Light Bracket - Link
Electrical
HowTo: Add AUX Input to Stock Bose Headunits - Link
HowTo: Convert Headlights from 9004 to 9007 Bulb Type - Link
HowTo: Create Your Own Angel Eyes - Link
HowTo: Disassemble/Fix Display/Troubleshooting of 95-96 Bose Head Units - Link
HowTo: Enable Low Fluid Washer Light - Link
HowTo: Install An Air Horn - Link
HowTo: Install Glass/Shock Sensor to Stock Alarm - Link
HowTo: Install Strobe Lights In Clearance or Bumper Lights - Link
HowTo: Make Clearance Lights Bright (95-96) - Link
HowTo: Make Cruise Control Always Ready - Link - Link2
HowTo: Make Sunroof One-Touch Open - Link
HowTo: Make Tails Red/Clear - Link
HowTo: Make Wipers Variable Intermittent - Link
HowTo: Make Your Alarm Beep - Link
HowTo: Replace Ignition Switch - Link
HowTo: Setup Home Link - Link
HowTo: Replace Window Regulator - Link
Engine, Exhaust, Intakes, Suspension/Handling and Brakes
Engine
HowTo: Change Clutch Slave Cylinder Hose - Link
HowTo: Change The Thermostat - Link
HowTo: Change Your Alternator - Link | Part 2
HowTo: Change Your Coolant - Link
HowTo: Change Your Oil - Part 1 | Part 2 | Part 3
HowTo: Change Your Spark Plugs - Link
HowTo: Clean Throttle Body (TB) - Link
HowTo: Clean the EGR Tube - Link
HowTo: Clean The Mass Airflow Sensor (MAF), TB, Idle Air Control valve (IACV), and Exhaust Gas Recirculation (EGR) - Link
HowTo: Do 60K Nissan Service - Link
HowTo: Install 00-01 Variable Intake Manifold (00VI) - Link
HowTo: Install Knock Sensor - Link 1 | Link 2
HowTo: Install Middle Eastern Variable Intake (MEVI) - Link
HowTo: Install Stillen Supercharger - Link
HowTo: Install Under Drive Pulley (UDP) - Link
HowTo: Install Y-Pipe - Link
HowTo: Re-Grease Starter - Link - Link2
HowTo: Remove Top Speed Limiter - Link
HowTo: Remove Upper Intake Manifold (UIM) - Link
HowTo: Repair Radiator Core Support - Link 1 | Link 2
Bonus Material
HowTo: Replace/Install Fuel Injector - Link
HowTo: Replace Drive Belts - Link
HowTo: Replace Fuel Pump - Link
HowTo: Replace Fuel Filter - Link
HowTo: Replace Water Pump - Link
HowTo: Rewire Fan For Manual Use - Link
HowTo: Seafoam Your Car - Link
HowTo: Troubleshoot Throttle Position Sensor (TPS) - Link
HowTo: Wrinkle Paint Valve Cover - Link
HowTo: Remove oil pans (upper and lowe) - Link
Exhaust
HowTo: Install B-Pipe - Link
HowTo: Install Warpspeed Y-Pipe Link
Intakes
HowTo: Create Hacked Airbox Intake - Link
HowTo: Install Pathfinder Throttle Body - Link
HowTo: Install Place Racing Cold Air Intake (CAI) - Link
HowTo: Make/Install Short Ram Intake - Link
Suspension and Handling
HowTo: Change Shocks/Struts - Link 1 | Link 2
HowTo: Fix Front Strut Bearing - Link
HowTo: Install An ADDCO Rear Strut Bar (RSB) - Link
HowTo: Install Front and Rear Strut Bars - Link
HowTo: Install Koni Front Inserts - Link or Link
HowTo: Install Koni Suspension - Link
HowTo: Measure Your Tires - Link
HowTo: Replace Wheel Bearing - Part 1 | Part 2 | Part 3 | Part 4 | Part 5
HowTo: Replace Lower Control Arm bushings - Link
Brakes
HowTo: Bed In Brakes - Link
HowTo: Change Front Brakes - Part 1 | Part 2 | Part 3
HowTo: Fix Parking Brake - Link
HowTo: Install Brake Speed Bleeders - Link
HowTo: Install Stainless Steel Brake Lines - Link 1 | Link 2
HowTo: Paint Your Brake Calipers - Link
Transmission and Drivetrain
HowTo: Convert From Auto to 5 Speed - Link
HowTo: Fix CV Joints - Part 1 | Part 2 | Part 3
HowTo: Install A Short Throw Shifter (STS) - Link
HowTo: Install Transmission Cooler - Link
HowTo: Install Valve Body - Link
HowTo: Remove/Rebuild Your Manual Transmission - Link 1 | Link 2
HowTo: Replace/Change Your Clutch - Link
HowTo: Replace Power Steering Fluid - Link
HowTo: Replace Steering Rack - Link
Finkle
Sep 27, 2015 09:53 PM
Greenmaxspeed
Aug 31, 2015 09:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
