5th Gen: What did you do to your 5th Gen today?
Old 02-20-2015, 05:31 AM
  #1641
D.Stillwell's Avatar
Originally Posted by 2kMaxim
Better start saving for the other 5 :P
For what it's worth, I think cylinder 1 misfire is common and is same **** that I had on mine. I've only replaced that one coil so far, and that was around 80k miles and I'm at about 103k miles now.
That said, they don't always all go bad.
D.Stillwell is offline
Old 02-24-2015, 06:44 PM
  #1642
CMax03's Avatar
I happened to be in the garage when my wife started the 03 this morning, and the starter turned over slower than normal, prompting me to check the battery voltage and the Altenator output voltage and even at 3000 rpm I'm only producing 12.8v...Damn it's altenator replacement time...Anyway I've ordered a Hitachi remanufactured Hitachi unit and hopefully it's here tomorrow...I'll purchase the possible failed part once I remove the defective altenator and disassemble, inspect, and test it....I'm sure it's the IC module/regulator that's defective and there's a web site, I went too that offers the internal components of altenators...My buddy's 350z failed about a year ago and I was ready to replace the failed part until I proved it to be the stator windings shorted out! Anyway it's a $30 core and I'll fix it, have it bench ran under load and set it to the side for a rainig day!
CMax03 is offline
Old 02-27-2015, 04:56 PM
  #1643
Sortus's Avatar
Today i did the GAB mod hanger method. Also did some detailing on the interior. Then it started snowing so i had to quit. Added a picture of the car with snow. My bad its to cold right now to take more.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-wp_20150227_001.jpg
Sortus is offline
Old 02-27-2015, 05:35 PM
  #1644
nestorlugo's Avatar
nestorlugo is offline
Old 02-28-2015, 08:47 AM
  #1645
CMax03's Avatar
Altenator made it here yesterday,So I removed the defective Altenator and installed the New altenator....pulled tensioner pulley, fans, and radiator....Got everything installed and topped off Coolant and started and volt was only 12.5v-12.8v !!!! WTF!!! Performed a Battery test with my analyzer and it should my Red Top Otptima having only 490cca compared to the rated 790 cca....I let it run for awhile and since the field voltage was low the was low....after about 20-30 min of idling the output was now a solid 13.0v and retested the battery and 545cca...So I'm headed in the right direction I'll let Advance test the defective altenator that wouldn't put out more than 12.0-12.4v....
CMax03 is offline
Old 02-28-2015, 02:37 PM
  #1646
george__'s Avatar
You got a defective alternator!!
Ahaha welcome to the club
george__ is offline
Old 03-01-2015, 04:41 AM
  #1647
^^ Nicely done on the alternator, big issue taken care of is always great!
As for my 5th gen, drove her to stealership, bought a new (7th gen) brilliant silver twin for her.
Cursed the salesman for making her 1st tank of gas be regular 87...What an idiot.
Planning on AE pedals install, full engine cleaning after the long winter, replacing all remaining Jap hose clamps with worm clamps, etc...soon as it gets warmer out again. Cant wait for the warm
Old 03-01-2015, 02:38 PM
  #1648
Unclejunebug's Avatar
^ Congrats on the purchase!
I had my front rotors resurfaced and did my second AT drain/fill.
Unclejunebug is offline
Old 03-01-2015, 02:51 PM
  #1649
Thanks!
Good work on the rotors and drain/fill, keeping the maxi nice and fresh.
Old 03-01-2015, 02:58 PM
  #1650
AT978's Avatar
Thanks!
My tranny bogs for the first block of driving, going from first to second every time, the same type of bog, but after that first shift then it's alright, should I flush?
AT978 is offline
Old 03-01-2015, 03:08 PM
  #1651
Thanks!
Fresh indeed. I recently bought my wife a sweet-a minivan so the Max needs to last me a good long while . I also restored the headlights.
I'd recommend a Drain/Fill over a full on flush just there's no confusion. The drain/fill process is cake and is a relatively cheap maintenance related thing to do.
Old 03-01-2015, 03:34 PM
  #1652
Nice. And I hear that. Trying to make mine last as well. Plenty of older Altimas/Hondas/Toyotaa and other cars at the dealer parking last night with people trying to upgrade. All those cars were at least half the age of my Maxima yet mine was the only one that left the lot and was in way better shape than any of those.
Definitely do drain/fill not full flush, especially if your tranny has already exhibited slipping. Flush can make things even worse.
Old 03-01-2015, 03:48 PM
  #1653
cornholio's Avatar
New battery to bring it back from the dead
cornholio is offline
Old 03-01-2015, 03:52 PM
  #1654
AT978's Avatar
Is the difference just not running new atf through or what? What is the difference between drain fill and flush
AT978 is offline
Old 03-01-2015, 04:15 PM
  #1655
A full on flush would have to be done at a dealership or some other auto-shop. They'll hook your tranny up to a machine that removes all the fluid, forces a solution through the transmission to remove sludge and other deposits, and then fills it up with new fluid.
A drain/fill is basically the same procedure as an oil change, just with your transmission. Pull the plug, drain the fluid, fill it back up.
Old 03-01-2015, 04:20 PM
  #1656
AT978's Avatar
Ohhhh yeah in that case, that's what I meant
AT978 is offline
Old 03-01-2015, 09:54 PM
  #1657
george__'s Avatar
You bought another Maxima?
george__ is offline
Old 03-01-2015, 10:06 PM
  #1658
What is that a joke? Lol
This is a Maxima forum after all, george
Btw, it's not another Maxima its to replace the wifes 7th gen that just got totaled.
Old 03-02-2015, 07:39 PM
  #1659
george__'s Avatar
Omg. I hope she's okay!!!
george__ is offline
Old 03-02-2015, 08:31 PM
  #1660
Yikes! Didn't realize the purchase was prompted by a wreck. I hope all is well.
Congrats on the purchase still, but that's a sucky reason to have to buy a car.
Old 03-03-2015, 01:12 AM
  #1661
Thanks guys! Luckily she was fine and I have to say 7th gen held up very well in the wreck.
It sucks for sure, having that be the reason for a new car. But, at least we got a better one than last time and upgraded.
Old 03-05-2015, 05:34 PM
  #1662
nestorlugo's Avatar
Installed homemade grounding kit... Name:  CAM00637_zpsbciqys77.jpg
Old 03-05-2015, 06:36 PM
  #1663
george__'s Avatar
Good job
george__ is offline
Old 03-05-2015, 06:52 PM
  #1664
Props for making your own. It's so easy and fun, better than paying for it.
Old 03-05-2015, 07:12 PM
  #1665
nestorlugo's Avatar
Thank you D.Stillwell ! Yea definitely almost free!
Good job
Thank you george_...!
I used 2 gauge 99% ofc wire
Big three is next....
Old 03-06-2015, 04:46 PM
  #1666
Blake2000's Avatar
Picked up 6th gen rotors and Calipers to start my Big Brake Kit 😍😍
Blake2000 is offline
Old 03-06-2015, 06:03 PM
  #1667
nestorlugo's Avatar
Originally Posted by Blake2000
Picked up 6th gen rotors and Calipers to start my Big Brake Kit ?de0d?de0d
Old 03-06-2015, 08:59 PM
  #1668
Blake2000's Avatar
And i replaced my old horn with a new one from a i30
Old 03-07-2015, 05:51 PM
  #1669
Blake2000's Avatar
Installed a new K & N air filter.... Also finished my Big Brake Kit upgrade for my front brakes 😍😍😍🙌🙌
Old 03-08-2015, 06:06 PM
  #1670
cornholio's Avatar
installed grounding kit and half-assed cleaned engine bay along the way. also dealt with this corrosion issue
cleaned this side
replaced the other piece for the positive terminal
was dark when i finished so didn't get final pics of the work
Old 03-11-2015, 03:29 PM
  #1671
ateick's Avatar
Pulled the blanket off of it and took it to the body shop for some TLC.
ateick is offline
Old 03-11-2015, 05:09 PM
  #1672
CMax03's Avatar
Redtop1 (original Red Top battery) was replaced with a New Optima Red Top battery (RedTop2) last night after RedTop1 measured an anemic 145 CCA from a 720 CCA rated battery....I charged the RedTop1 for about 6-7 hrs last night and the CCA were then measured at about 575 CCA.... I'll install RedTop1 in my 4th Gen Maxima and monitor the CCA over the next week or 2, just to see if it starts to decline again and then I'm sure I have a damaged cell internally...My altenator took longer than I thought, usually rockauto takes about 2-3 days to deliver whatever I order and this time it was a 5 day wait....So I may have burned or damaged a battery cell riding around with a low output or no output altenator.....Redtop2 measured a whooping 840 CCA before I installed it, and my new Altenator's output is a staedy 13.0v- 13.2v under a load!
CMax03 is offline
Old 03-11-2015, 07:17 PM
  #1673
Nicely done Cmax. I may get myself a redtop soon as well, my 3yr old duralast is not likely to last another winter.
Old 03-12-2015, 12:08 PM
  #1674
CMax03's Avatar
Rechecked CCA on both RedTop1 and RedTop2 and both are still rocking....RedTop1 isn't hooked up to anything yet and still has 643 CCA, RedTop2 measured 853 CCA...Is it overcharging? The both batterys are identical and are rated at 720 CCA....
CMax03 is offline
Old 03-12-2015, 02:22 PM
  #1675
2kMaxim's Avatar
Bought an AEM dry flow cone filter and swapped out my cheapo Spectre oil filter.
2kMaxim is offline
Old 03-12-2015, 03:29 PM
  #1676
Good move, that's a way better setup. AEM FTW
Old 03-12-2015, 03:54 PM
  #1677
2kMaxim's Avatar
That's what I figured...The whole oil thing is annoying.
2kMaxim is offline
Old 03-13-2015, 12:48 AM
  #1678
CMax03's Avatar
I've got a couple of AEM's 3" and 6" cone filters and I think R2C's filters flow smoother....especially the 6" cone filter.
CMax03 is offline
Old 03-13-2015, 05:18 AM
  #1679
Agreed. R2C filters are excellent, I'd put them #1 overall, followed by Amsoil and AEM.
But, you can also buy 2 comparable AEM's for the price of 1 R2C. They are expensive, and I'd say would provide most benefit in forced induction motors, not as much for an N/A Maxima.
Also, I really like the AEM material for how clean it remains, because it pretty much never gets dirty for me and I've seen tons of sand and dust this winter. Id think the R2C mesh on top of the filter element might make it harder to keep clean long term?
My AEM 6" vel. stack flows well, you can hear it just sucking air even sitting at idle.
Old 03-13-2015, 12:07 PM
  #1680
ramriv777's Avatar
03 SE TE. Replaced rear calipers, rotors and pads. Caliper locked and ruined the rotors.
Sent from my iPhone using MaximaOrg
ramriv777 is offline
Quick Reply: 5th Gen: What did you do to your 5th Gen today?
