List tire and best 60 foot achieved using them at the dragstrip.
Originally Posted by 6spd_Hayes
Tire Used: BFGoodrich G-Force Drag Radials
Condition/Wear: Good - Not street driven, right at 60 passes
Tire Size: 225/45-17 at 15.0 psi
Best 60: 1.952
Wheels: 17"x7" Keonigs Traffiks (15.9 pounds each)
Wheel/Tire Weight: 38.5 pounds each
Best 60: 1.952
I plan on using them on the street, and the track this being my first DR's I have no Idea what to expect.
I also have a pair of slicks people tell me for right now I'm not pushing a whole lot of power for them to actually help on times. The g-Force T/AŽ Drag Radials would do just fine for my N/A setup.
Do you guys agree..?
Originally Posted by Aaron92SE
Tire Used: 18lb BFG Gforce Drag Radials
Condition/Wear: Good with only about 40 passes
Tire Size: 205/50R15
Best 60: 2.08
Other notes: 2900 rpm stall torque converter, 410lbs of weight reduction, and lots of power modifications. Tire pressure was set at 17psi.
Launched off idle; 750rpm. I tried stalling it up anywhere between 1000 and 2900 and I burned the drag radials down and only made my 60 foot worse. First time I tried to stall it to 2900, I spun the tires and got a 2.35 60 foot. Once I get slicks, my 60 foot will go down some more since I will be able to stall it up to close to 3000.
Wheels: 11lb Millenia wheels
Combo weight: 29lbs
Best 60: 2.08
Combo weight: 29lbs
UPDATE:
Tires: Yokohama 215/60/15 All-season mounted on Stock 15" Sawblades.
Condition: Good.
Best 60 foot: 2.022
M&H 23X8.5X15 slicks mounted on sawblades.
Best 60 foot: 1.759
Notes: 5-speed VQ35-powered 4th gen.
Condition: Good.
Best 60 foot: 2.022
Best 60 foot: 1.759
Nice '60, I just purchased a set of those 225 45 17 , So you don't use them on the street, Why? I plan on using them on the street, and the track this being my first DR's I have no Idea what to expect. I also have a pair of slicks people tell me for right now I'm not pushing a whole lot of power for them to actually help on times. The g-Force T/AŽ Drag Radials would do just fine for my N/A setup.
My launches generally run from 2500-3000 rpm, and letting out clutch in a controlled manner, only giving tires on launch a light chirp. That varies little from my launch technique on street tires. It is all about the clutch slip for me. I have gotten a best of a 2.105 sixty on worn stock Potenzas and stock 17's.
Once I break the 250 fwhp, then I may trade up to slicks.
So on the 225-45-17 BFG G-force DRS, are you doing a big burnout?
I heard well from past experience on the comp t/a drag radials on my supra that if I did a good 5-7 sec burnout and kept them right at 16psi they pulled consistent 1.7 60fts, is this the same turnout on these tiny slicks
I think my car is pushing right around 215-220fwhp.
And what motor mounts are you folks running?
vnt
?I think my car is pushing right around 215-220fwhp.
vnt
vnt
vnt
update:
Tire Used: Hoosier Drag Radials:
Condition/Wear: New
Tire Size: 225/50/16 (15.5 psi)
Best 60: 1.97
Rims: SSR Competitions 16 x 7.5
edit: same here on the track i got the 1.97 60 foot the elevation is lame, so i didnt beat my pb hit a 14.0 but the correction factor is something like .18 or .2. On another note its hard to break old habits, im still not launching at high enough revs i dont think, got to hammer that into my head. my best et is 13.97 on the toyo proxes coming from a 2.15 60 foot. its tough over here thats for sure. i need a good track !
post 49 below: my trap speeds where the same on the same track mentioned above with the proxes t1r and hoosiers 96 mph which is also 2-3mph slower from some of my best this year. i used to read about guys racing on tracks with a high elevation but never thought anything about it, but now i can say it stinks ! i have trapped 99.5mph with the toyo proxes t1r and also trapped 99.5mph with the hoosiers at around 15.5 psi.
Condition/Wear: New
Best 60: 1.97
I've never seen a decrease in MPH when running slicks except when I drop the pressure on purpose below 11psi. I usually end up right at 11.5 or 12psi on slicks. One night I was getting so many runs in, and no chance for a personal best due to the hot summer weather, I decided to just see what would happen to my trap speeds if I dropped the pressure lower than normal, below 11psi I did start to lose some trap.
I've never used slicks shorter than stock tires though, always 26" for me on both my maximas. My highest trapspeeds have always been on my slicks.
Originally Posted by dr-rjp
15" Fuzion HR-1's on original alloy wheels, w/ less than 3000 miles of wear.
Stock I30 setup except for Y-pipe & K&N drop in.
2.29
2.29
Update:
Tire Used: 14 lb Mickey Thompson ET Drags (Slicks)
Condition/Wear: Slightly Used
Tire Size: 22x8x15 (25 psi)
Best 60: 1.99
Rims: 11lb 15x6 Mazda Millenia wheels
That was on my 13.79 @ 100.34 mph 1/4 mile run. That night, I had several 1.99x 60 foots and I think one 2.00x 60 foot. And my traps were in the 100.x range all night.
25psi is a lot for these slicks. I was only barely able to chirp them on a couple runs after a little burnout. You want to run as much pressure as traction allows. I have no reason to drop the pressure below 20psi right now with the small amount of power I'm running.
My trap speeds don't suffer with these small tires b/c of my gearing. I need shorter gearing to get me revving more in the top of 3rd when I go through the traps. But for other cars, it can hurt traps I guess. It all depends on the gearing and the car.
Best 60: 1.99
I noticed absolutely no difference after installing my ES motor mounts. I would say there is no downside to that particular mod.
vnt
are they quite harsh, as far as vibration?
vnt
vnt
The vibration is bad enough at idle that my Bose 6 disc in dash has a hard time playing without skipping. Just a note, I am also running the ES subframe bushings.
I have a definite vibration with the ES motor mounts. ... Past 1k though, it smooths out and you can't feel it any longer.. Just a note, I am also running the ES subframe bushings.
I installed the bushings/mounts the same time as I did my engine swap so I wasn;t sure which one was the culprit. I was leaning towards my flywheel as I had to have some welding and machining done on it. I sent it to a shop to be balanced and thought it was possible that they may have screwed it up.
I am going to swap the stock subframe bushings back in and see if that cures the problem.
Just a quick burnout, nothing 'top fuel'.
I am running the Energy Suspension MM's.
Hey,
Did you ever run it on the drag radials prior to the ES MMs? And if so what was the outcome?
vnt
How much did it cost for your VQ35 swap?
Originally Posted by JClaw
UPDATE:
Condition: Good.
Best 60 foot: 2.022
Best 60 foot: 1.759
Condition: Good.
Best 60 foot: 2.022
Best 60 foot: 1.759
So, I was wondering how much the how change-over cost, and what 4th Gen parts did you have toi change besides the engine and tranny?
Also, what was your best time on your 3.0L?
Thanks!
Hey,
vnt
vnt
Over in another thread in the 4th Gen forum, entitled, "What would you do if you won the lottery," a lot of members talked about doing a 3.5L swap.
Thanks!
Thanks!
3.5 swap can be done for 1100-1200$. I only ran stock and went 15.00@92 with the 3.0.
I'd like to know what came with the 3.5L at that price? Did you use its ECU as-is, or did you have to get it reprogrammed? Also, when you talk about that price, I am assuming that it was a DIY job, right? For the mechanically-challenged, how much should I expect to pay a mechanic to do it?
Thanks, in advance!
Serotta33
Sep 17, 2015 12:14 PM
