1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
15.90 1/4 mile time
Old Nov 16, 2005 | 06:26 AM
naplesmaxima aka Tommyali the scammer!'s Avatar
I scam therefore I am
15.90 1/4 mile time
i ran a 15.90 with
18 inch axis seven mods
short ram intake
1 stone racing header installed
stone racing y pipe
stock cat
2.5 inch mandrel bent b pipe
no resonator
megan racing muffler with 4.5 inch outlet
my car is a 1996 automatic with 112,000 mile
no weight reduction
and about a 400 pound system
15.40
everything as above with the addition of the 2nd header and a high flow cat
next im planning on doing the motostorm UDP $109
im thinking i might dop down to 15.20
after that TS 7100 ECU $700
might drop down to 15
and then zex 75 shot
hoping for low 14's
Old Nov 16, 2005 | 04:41 PM
Ceasars Chariot's Avatar
Old Maxima Legend
good luck with it ! how you like those headers ?
Old Nov 16, 2005 | 07:09 PM
NmexMAX's Avatar
dot dot dot ...
So 5 tenths w/ 1 header
Dyno time
Old Nov 17, 2005 | 07:15 AM
5 tenths with the addition of the 2nd header and the high flow cat
Old Nov 17, 2005 | 07:16 AM
the headers are awesome for $300 you cant beat them they took off about 6 tenths of a second by adding the headers (my guess)
Old Nov 17, 2005 | 02:02 PM
NmexMAX's Avatar
dot dot dot ...
Dyno tuning time
Old Nov 18, 2005 | 09:50 AM
Nealoc187's Avatar
SLOW
I have a question. How do you have 400lbs worth of stereo equipment in your car? I know that if you have a show quality setup where your entire back seat and trunk is a mass of subs, amps, caps, MDF and fiberglas, it will weigh alot. But I see people post about how they have 100, 200, 400lbs worth of stereo crap in their car on the .org all the time. Back when I had stereo stuff I had two 10" Rockford Punch Powers, a 400 watt amp, and a sealed box and the entire setup weighed probably 75lbs. What the F do you have in your maxima that weighs 400lbs? 22 subs and 15 amps or what?
Old Nov 18, 2005 | 10:00 AM
Nealoc187's Avatar
SLOW
BTW if you are thinking of adding a TS ECU and then nitrous you might want to do a little more reading on that subject. Hate to see a blown motor.
Old Nov 18, 2005 | 03:14 PM
trust me i have about 400 pounds in my trunk 2 huge amps 1 smaller amp 2 huge 12's 1 inch mdf custom box 1 inch plexiglass tons of dyna mat 2 optima's 2 cap's
i used to have zex 75 shot dry on my car for about 6 months and it worked fine and then i sold it. and im going to buy another kit
Old Nov 18, 2005 | 06:09 PM
japmaxSE's Avatar
Go Get a Life!
So you were driving with 1 SR header with 1 factory one and now you have both I'm lost
Old Nov 18, 2005 | 07:57 PM
I30tMikeD's Avatar
Why don't you just put on your stock rims and take out the system instead of buying go fast mods to make you as fast as you should be stock?
Old Nov 18, 2005 | 09:14 PM
TurTLe*'s Avatar
you happen to have info or site on where we can look at stone headers.
Old Nov 18, 2005 | 11:20 PM
2 Da Max's Avatar
wtf!! 1/10ths of a second with just the header?? u sure you had the same amount of gas and weight?
Old Nov 19, 2005 | 04:16 AM
maximaintheface's Avatar
what is a huge 12? my set up i had with 2 12's a pretty big box 2 amps and a capacitor was prolyl only 150 lbs.
Old Nov 19, 2005 | 04:52 AM
japmaxSE's Avatar
Go Get a Life!
What I don't understand is why did you go to the track if you only had on one SR header? why ould you even install one header?
Old Nov 19, 2005 | 02:06 PM
Nealoc187's Avatar
SLOW
My point is that TS ECU gives you advanced timing and leaner AFR. You have these things then add nitrous and you could end up blowing your motor.
Old Nov 19, 2005 | 06:36 PM
i cant put the stock rims back on the car i sold them and im not taking about the system.
to clear a few things us
i ran a 15.9
short ram intake
1 stone racing header installed ( at the moment i had only put on the front one didnt have time to put on the rear on i installed the rear one the next weekend)
stone racing y pipe
stock cat
no resonator
no weight reduction
next i ran a 15.40
15.40
everything as above with the addition of the rear header and a high flow cat
next im planning on doing the motostorm UDP $109 i think that will drop me down to 15.2
after that TS 7100 ECU $700 might drop down to 15 and then
and then zex 75 shot hoping for low 14's
Old Nov 19, 2005 | 08:18 PM
CreativeDesignz's Avatar
i ran a 15.6 with my stock infinti I30 (97). those times seem way off for all those mods u should prob be way faster. and i ran with my system in my trunk which is prob just as heavy if not heavier than yours. and the I30 is heavier than the max over all anyway. i saw a thread that u changed ur knock sensor that could have been the culprit.
Old Nov 19, 2005 | 10:30 PM
TurTLe*'s Avatar
^ yea i assume it would be KS that made him run stock number. There hasn't been enough info to say that a UDP will make you run any faster/slower YET.
have you ran your car on the dyno yet?
Old Nov 20, 2005 | 10:23 PM
Fr33way™'s Avatar
Wild for Width
Thow a couple sandbags in there for the next run.
Old Nov 21, 2005 | 07:41 AM
stephenlc's Avatar
I ran a 15.6 stock in my auto. I have the Stone Montain Headers too. But I am going to remove the header parts and just keep the y-pipe for now because I am going to send them off to get Jet hot coated, with mingos turbo pipe kit. I want to go back to the track before and see how much of a difference between my stock time and the header times.
Old Dec 8, 2005 | 07:52 PM
gen4maxse's Avatar
why would you run with your system? and unless you have like 10000 watts i dont think 3 amps a 12 and dyna matt adds up to 400lbs
Old Dec 10, 2005 | 09:41 AM
Charcoal95GXE's Avatar
Yeah neal, 7100 RPM redline...with a lean N/A tune will be GREEATTT with a 75 shot...rofl..
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Maxgig
Aug 18, 2015 09:17 PM
yat70458
Aug 3, 2015 01:16 PM
