1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
new pb 2.048 60ft and 14.307 1/4
Old Nov 24, 2006 | 07:18 PM
  #41
babymac's Avatar
BOOST 4 LIFE!
Originally Posted by t6378tp
no I will not manually shift but I am just concerned about the tranny not shifting as fast with the added power. you figure most guys are runnig 5-speeds but with a auto you have almost a extra 100hp (75nitrous + 20vi) there is a good chance the tranny will slip alittle.
A tranny cooler would GREATLY reduce tranny slip and I don't think its possible to hit the rev limiter in a auto if you let it shift itself, so I wouldn't worry about that either.
Old Nov 24, 2006 | 08:13 PM
  #42
grey99max's Avatar
LandShark has Cosworth
Question:
I am looking to install a mevi and was wondering if it was really worth it. My concerns are that I do not have a raised rev limiter and with the extra power from the mevi + nitrous I might hit the rev limiter and I do not want to spray into the limter cause it cuts the fuel and this would be bad. Now the question, is the mevi worth it and what kind of times can I look to gain, also can a msd rpm box control multi functions like the mevi and shut down the nitrous around 6200-6500rpm so the tranny can shift without the added stress.
I use a stock ECU and my dyno shows power going up to fuel-cut , even as N/A. I see the same upwards curve on HP while spraying. My MEVI does me proud. The switchover point is set to 4800 right now.
A 8969 MSD can control two output wires. One (yellow) switches to ground when the set point is reached. The other wire (grey) is grounded until the RPM set point is reached. I use 6200/6300/6400 for the shift point ON setting, and I set the OFF RPM at 12,000 - this way I get the right response from the MSD. Fuel-cut is 6650 RPM. I bounce off fuel-cut fairly often when doing a water-box burnout.
I just today wired my Shift_Fast w/MSD to cut second-stage nitrous when the shift point is reached, Now I won't second-stage-spray when shifting. This seemed to work well last weekend.
The MSD 8969 can be used for all sorts of RPM-related things. I have another that controls the MEVI switchover point using an electric door-lock motor. The ECU Tach output feeds the MSD no prob.
The Shift_Fast controller I built shifts the automatic very quickly when the programmed RPM is reached - no reason to try and watch the tach.
Old Nov 24, 2006 | 08:24 PM
  #43
Nealoc187's Avatar
SLOW
My M&H 26x6x15 slicks and Mazda Millenia 11-spoke wheels were a 25lb combo. The 11-spoke millenia wheels are 11.5lbs and the 9-spoke millenia wheels are 12.5lbs.
Old Nov 25, 2006 | 04:22 AM
  #44
t6378tp's Avatar
Turbo 3.5
Thank alot for the input guys it gives me some idea's for this winter and where I should go next.
I am pretty sure I'll break 13's my next time out at the track, and just looking to see what it will take for a mid 13 run with a 75shot
lrb6805
Sep 30, 2015 08:12 AM
jerrod99_se-l
Sep 16, 2015 02:39 AM
ag90fox
Sep 9, 2015 12:22 PM
Bryan H
Nov 28, 2000 10:54 PM
