1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
What should I run and could I beat a stock STI?
Old May 4, 2007 | 08:49 AM
  #81
Ceasars Chariot's Avatar
Old Maxima Legend
true i wish i had the extra money to just get a setup like that for a non event kinda day. dan whats the lastest, might need to send you over a pm to catch up.
Old May 10, 2007 | 12:53 AM
  #82
Revs2Hard's Avatar
BARF
~~~Im running my car this saturday 5/12/07~~~
This is just going to be a test day, because I finaly got the nitrous kit and all of its components installed. However I have not gottin my Y-pipe in and have a broken rear motor mount. Im going to make a couple of easy passes down the track pulling the spark plugs after each run. If everything is ok I will have the rest of my parts including a couple of polly motor mounts installed and then see what it'll really run. If not I just might have to have a walbro put in when the mounts are being changed.
Old May 10, 2007 | 03:34 AM
  #83
toddemullins's Avatar
I'd personally just spend the time putting in the Y and mounts, and wait for the track. You are going to be so much happier when you get the Y installed and the urethane mounts. I'm in the same boat...can't wait to get to the track, but don't want to go until I install my clutch, motor mounts, all front urethane bushings installed. I just know I'll be unhappy with the timeslips.
Old May 30, 2007 | 10:01 PM
  #84
GoalieKeg's Avatar
Originally Posted by MaxBoost925
STi is NOT slow...
You all are thinking about WRX's. now those are slow.
http://forums.maxima.org/showthread....88#post5734888
Shhh n00b!
Back on topic...With your mods, you will be pretty damn close to an STi if he is a mediocre driver, and you're an excellent driver. Also, if you tune properly and get rid of some weight that will help significantly.
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
