1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
4th gen, 13.86 @ 100.11
Old Jun 25, 2007 | 06:55 AM
cardana24's Avatar
Blown
I went to test and tune at Richmond Dragway on Friday 6/22/07. I got in a total of 6 total runs. My best run was my second run, here is the full slip.
rt: .6710
60': 2.0087
330': 5.7814
1/8 E/T: 8.9202
1/8 mph: 78.63
1/4 E/T: 13.8643
1/4 mph: 100.11
I backed it up again on my third run with a 13.98 @ 98.9, and then again on my 6th run with a 13.94 @99.65
My other three runs I was in the mid to low 14's. On all of my 14 second runs my launches were horrible, and I hit the rev limiter on two of the runs. All in all I am very pleased considering I bettered my PB by ~4 tenths and 3 mph. When I had run my PB before It was probably close to 35 degrees cooler as well. I am looking forward to running again when it cools down a little bit to see what I can really get out of this set up. It would also help if I could get my 60 foot below 2.0 but I am only on drag radials and I suck at burning out.
My mods are all on my 1995 5-speed GXE:
I/Y/E
JWT ecu
00VI tuned with a VAFCII
Fidanza flywheel w/ fifth gen clutch
I am not sure of the weight of my car, but I had an empty trunk and I took the passenger and rear seats out of the car. This is my only weight reduction (other than aftermarkert parts that may weigh less thant he stock parts).
I have videos of all of my runs, but I have no clue how to put them online and they are not on my camera, so if I can get the camera and film I may try to figure out how to upload them on youtube or something.
Old Jun 25, 2007 | 07:29 AM
Tatanko's Avatar
Bacon Lover
Good runs. Glad to see everything is working out great for you with your setup. Definitely return when it's cooler
Old Jun 25, 2007 | 07:33 AM
Kevlo911's Avatar
Kevlo for President
Very nice
Old Jun 25, 2007 | 08:22 AM
NCSU_MAX's Avatar
Maximoneypit
great time carson!
Old Jun 25, 2007 | 09:04 AM
NmexMAX's Avatar
dot dot dot ...
So what was different vs your old PB?
Great numbers for sure. 60' is absolutely great man, way to get it down.
21.48MPH gained in the 2nd 1/8th, also quite nice/indicative of some nice top end power for N/A 3.0.
Old Jun 25, 2007 | 09:21 AM
Zack342's Avatar
Awesome times. What wheel tire combo are you running?
Old Jun 25, 2007 | 09:44 AM
cardana24's Avatar
Blown
I need to find my old slips to see exactly where the gains are. Also where do I go to find the Air density? I would like to see that too.
The 60' is usually right around what I get. The other 13.9 runs that I posted were all 2.0x 60's as well.
If I can find my old slips I'll post back. I know I posted a thread when I ran the 14.2. I'll see if I can find it.
Old Jun 25, 2007 | 09:46 AM
NmexMAX's Avatar
dot dot dot ...
Here it is.
This was my second time at the track with my 95 GXE. I have i/y/e. Stock ecu and stock intake manifold. Millenia wheels with ~ 20 psi in my BF Goodrich Drag Radials. I only had the driver seat in the car and I took out the jack and the spare. I have done better in the past when it was cooler out and less humid but I just thought I would post my slip. Any comments are welcome.
r/t: .9071
60': 2.0778
330': 6.0263
1/8 et: 9.2920
1/8 mph: 76.31
1/4 et: 14.4696
1/4 mph: 94.84
Is only gaining 18 mph in the final 1/8 about right?
Old Jun 25, 2007 | 10:34 AM
cardana24's Avatar
Blown
Here it is.
that's not it. I must suck at searching. When I ran the 14.2x I was in Rockingham NC. It was before I ran the time you posted. Can you sort threads by ones you started in certian forums?
Old Jun 25, 2007 | 10:58 AM
DasYears
those are good times, now ditch the JWT and EU it up for a low 13 pass
Old Jun 25, 2007 | 11:06 AM
cardana24's Avatar
Blown
I doubt EU would get me much lower. I would need to find a good bit of extra power to see low 13's. I don't plan on doing any thing else for weight reduction other than what I already do when I go to the track. I understand Dandy Max did it, but I am guessing his car was a good bit lighter than mine.
Old Jun 25, 2007 | 01:51 PM
Neapawn's Avatar
Nice time I love it
Old Jun 25, 2007 | 04:27 PM
NmexMAX's Avatar
dot dot dot ...
Although the EU may not give much more power, it WILL help in terms of better metrics re: faster track times. 2 step comes to mind.
Old Jun 25, 2007 | 04:51 PM
DasYears
yeah, i was thinking two step, timing advance and more accurate A/F adjustment., not to mention further extended rev limit if he dares
Old Jun 25, 2007 | 07:37 PM
t6378tp's Avatar
Turbo 3.5
congrats nice times and 60ft
you can remove the back seat and dash brace under the steering wheel for more weight reduction
Old Jun 25, 2007 | 07:52 PM
KRRZ350's Avatar
very very very impressive! Congrats
Old Jun 25, 2007 | 08:00 PM
NmexMAX's Avatar
dot dot dot ...
Making more power vs putting the power already at hand to the most efficient use is what I meant.
Can't seem to find it either.
Old Jun 25, 2007 | 08:34 PM
cardana24's Avatar
Blown
If I could find out how to search threads started by me in this forum I could find it.
yes 2 step would help with launching, and maybe the EU would help the timing some. i am not sure what Jim Wolf does with the timing, but I know it is altered. And as far as running more efficient A/F I did dyno tune and I set my VAFCII where I want it, so i don't know what more can really be had there.
Old Jun 25, 2007 | 08:50 PM
NmexMAX's Avatar
dot dot dot ...
Come on, your search with that criteria IS possible.
Just spend a few minutes with the search feature and you should get the hang of it.
Old Jun 26, 2007 | 03:41 PM
t6378tp's Avatar
Turbo 3.5
if you are going to take quotes than get it right this is what I said
you can remove the "back seat and dash brace" under the steering wheel for more weight reduction
there is a metal brace behind the pad which he can remove
Old Jun 26, 2007 | 05:12 PM
NmexMAX's Avatar
dot dot dot ...
Ok, stop bothering me
I still understood it as back seat AND dash brace under the steering wheel. No mention of said metal brace behind pad in back seat area.
But whatever, be more informative and this type of thing wouldn't happen.
Old Jun 26, 2007 | 06:53 PM
1chewabacha1's Avatar
Thread hijacked.... Nice times man. Anyone know if I have a chance to run times as good as these with a MEVI setup and no afc tune?
Old Jun 26, 2007 | 06:58 PM
NmexMAX's Avatar
dot dot dot ...
Only one way to find out
Old Jun 26, 2007 | 08:33 PM
DandyMax's Avatar
3.5 in the works
Nice times Carson. This is the N/A car I take it...
Old Jun 26, 2007 | 08:58 PM
Jason R's Avatar
aka UNCDooD
that is correct. his supercharged car went 13.6s @ 107 or 108 last time we were out at the track.
Old Jun 27, 2007 | 05:58 AM
Ceasars Chariot's Avatar
Old Maxima Legend
woot woot !! good show !! man sneak that camera and toss the runs up on youtube, i got to see it!!
Old Jun 27, 2007 | 06:04 AM
cardana24's Avatar
Blown
Originally Posted by Jason R
that is correct. his supercharged car went 13.4s @ 107 or 108 last time we were out at the track.
fixed
Dandy, yes this is the N/A car (I wouldnt post a 100 mph trap if it was my supercharged car )
Ceasar, I'll try to get at least one run on youtube. But like I said its not my camera so I will have to see if I can get it some time soon.
Old Jun 27, 2007 | 06:41 AM
DandyMax's Avatar
3.5 in the works
fixed
I figured as much but I thought I'd ask the stupid question anyways, lol.
Old Jun 27, 2007 | 07:03 PM
MaximA StyLeZ's Avatar
so what rpm do you have the vafc set to activate the 00vi ? Great job, i was aiming to run low 14's with my mods, and maybe it can happen.
Old Jun 27, 2007 | 07:12 PM
cardana24's Avatar
Blown
5 grand. I found that was the best spot. I made one dyno run with the intake "closed" the whole time, then did another run with it "open" the whole time and the set it where the lines crossed and it was right at 5k.
good luck getting to your goal. Before the ECU and 00VI, I was running steady 14.3's, with a PB of 14.2x.
Old Jul 16, 2007 | 02:02 PM
ajcool2's Avatar
Carson is your redline extended?
Old Jul 17, 2007 | 05:24 AM
cardana24's Avatar
Blown
yeah, its at 7200
Old Jul 30, 2007 | 05:55 PM
bigj01AE's Avatar
What RPM do you launch at? What RPM do you shift at? What gear and how many revs are you turning when you trap. Thanks.
Old Jul 30, 2007 | 06:49 PM
STILLENGLE's Avatar
nice man..
Old Jul 30, 2007 | 07:45 PM
nismology's Avatar
Originally Posted by STILLENGLE
nice man..
You don't say much of anything else, do you?
Old Jul 31, 2007 | 05:00 AM
STILLENGLE's Avatar
Good Runs Man. your gonna put spray in it or no
Old Jul 31, 2007 | 05:26 AM
cardana24's Avatar
Blown
I don't have a specific RPM that I launch. It's normally between 2 and 3 grand. I slip the clutch, then go to the foor as I think the car can hold it. When I cross through the traps I am either about to hit the rev limiter in 3rd or else I just switched to 4th, I could not tell a big difference one way or the other between shifting to 4th. My rev limiter is at 7200, I usually try to shift as close to that as possible (according to the factory tach.).
To the guy who asked about spray, yes I have thought about spraying it. I'll keep you posted. Currently the car has a very useable/streetable power band, its a very fun car to dive, so if I do spray it will not be any time before next race season.
Old Jul 31, 2007 | 06:30 AM
STILLENGLE's Avatar
nice man. keep me posted.
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
