1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
96 Auto GXE 1/4 mile
Old Apr 29, 2008 | 08:20 PM
khantalha+'s Avatar
Took my 96 Automagic Gxe out on track today....weather was around 45-50 degrees...... my beast 1/4 mile pass was 15.3651 secs.... i did pull the spare tire, jack, and all the seats out except for the driver's..... got that ebay CAI (PR LOOKALIKE), y-pipe, hi flow cat, and pacesetter catback....w/ UDP.... had about 7 gallons of 87 unleaded in the tank....ran on 20th aniv 17"s with 225/55s in the back and 225/45s in the front had my coilovers set to stiff also.....made 3 passes but this was the best one....
REACTION --- +.6260
60FT --- 2.3642
330FT --- 6.5070
et @ 594FT --- 9.2929
1/8 ET --- 9.9189
1/8 MPH --- 71.88
1000' ET --- 12.8240
1/4 ET --- 15.3651
1/4 MPH --- 90.52
it was kind of cold and front tires were at 35 psi.... made all my passes of with O/D off....had my cousin runnin 14.7-14.8s with his 04 6spd with CAI and 93 octane.....thats not even close to what i expected from my car...i thought it was a easy 14 sec car but i guess not, or what do you guyz think...i still have the 15" sawblade rims.... should i use those with 28-29 psi in the front tires and with pure 93 octane to be able to make a 14 sec pass...i wanna see it break in 14s before i put a VI in it...i do have my 95 5spd se that runs 13.9-14.1 N/A with mevi, injen cai, y-pipe, udp, test pipe and a 2.5 inch megan catback and a lightened factory flywheel ....
Old Apr 29, 2008 | 10:44 PM
ajcool2's Avatar
If you can get better 60's you should be able to get a 14 second pass. 15.3 aint bad though.
Old Apr 30, 2008 | 06:46 AM
97SMG's Avatar
Not bad of a run considering you had a really heavy tire combo. Should have thrown those RX7 wheels that you have in your sig
Old Apr 30, 2008 | 10:55 AM
khantalha+'s Avatar
yeah dude i sold em but i still have those 15" sawblades and btw that my 95 blue in my sig..
Old Apr 30, 2008 | 10:57 AM
khantalha+'s Avatar
and what about O/D off... how about i leave it on next time...?
Old Apr 30, 2008 | 11:04 AM
ajcool2's Avatar
Keep it off and turn it on when you hit 80 mph. Thats what I do.
Old Apr 30, 2008 | 11:17 AM
khantalha+'s Avatar
aite i ll try that with my 15" rims see what it does...tnx man
Old May 1, 2008 | 03:25 AM
Grand_hustle17's Avatar
^^^ 17's a nono you could have done way better, like ajcool said you could have done 14's, i had exact same mods with spare in the back and did constant 15.1's and a best 15.0 with 95 GXE
Old May 1, 2008 | 11:08 PM
khantalha+'s Avatar
aite ill try that next time before i install my 00vi
Old May 2, 2008 | 06:16 AM
good luck keep us posted
Old May 2, 2008 | 07:37 AM
Scottwax's Avatar
That's Mr. Detail to you
With a 90 mph trap, you really need to add more power to get into the 14s. Improving your 60' will help, but a 90 mph trap would be pretty weak for a 14 second car.
Old May 2, 2008 | 08:29 AM
ajcool2's Avatar
So what you trying to say?? lol J/K
Old May 2, 2008 | 04:50 PM
khantalha+'s Avatar
the thing is this car pulls way harder/faster than my 95 5spd(in my sig) which is a late 13sec car with mevi but 90 trap was my issue tooo.... i did have my overdrive off in both passes and ended up with two almost identical times with a difference of .06 mph and .13 Secs...i ll give it another shot cuz my goal is 14.5 or below before this summer with my 96 auto...
Old May 2, 2008 | 04:54 PM
khantalha+'s Avatar
and by the way... found me a 5spd tranny for $71.00 with 30 day warrantee but had to pull it out myslef from a junk yard with no torches or jacks allowed.....took me three hours....its still in good shape...
Old May 2, 2008 | 05:23 PM
same goal with my 2K auto, but O/D means nothing (except for running up top) unless your car goes through all 3 gears in the 1/4 then its pointless
Old May 2, 2008 | 08:47 PM
khantalha+'s Avatar
yeah i feel ya i guess it will come in handy with a vi swap, vafc, and a adjustable fpr....
Old May 3, 2008 | 09:37 AM
keep us posted
Old May 3, 2008 | 04:51 PM
khantalha+'s Avatar
i sure will
Old May 3, 2008 | 08:02 PM
Nismo87SE's Avatar
Its the gear ratios in the auto that keep it from running good ETs. To improve your ET you might want to consider running some smaller DRs or slicks, something like a 22-23in slick. Then a higher stall TC would boost off line power even more. These mods can make an auto competitive with a 5spd. Otherwise the ideal setup is to install a 4.0-4.1 final gear into auto which should be good for speeds up to 110-112mph in 3rd gear. Cruise at 60mph would be 2200-2300rpm vs 2000rpm stock.
Old May 3, 2008 | 08:18 PM
^^^ continue
Old May 6, 2008 | 12:05 PM
NmexMAX's Avatar
dot dot dot ...
^^^ continue
IIRC, the L31 Altima (QR4AT) has essentially the same tranny as us (5gen), minus the FD.
Here's some info on it.
http://forums.maxima.org/showthread....t=#post3899299
DAVEB quoted me 94$ for the FD itself.
markevans999
Oct 25, 2015 08:27 AM
rnb754
Sep 14, 2015 11:39 PM
LtLeary
Sep 14, 2015 12:33 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
ag90fox
Sep 9, 2015 12:22 PM
