1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
My First Ever 1/4 Mile- What are other 5th Gen 3.0s Running??
Old Aug 16, 2011 | 07:45 PM
jbrooks870's Avatar
Well long story short Ive never been to track and decided to go with along with my buddy and his bolted 5.5 Gen. Obviously his car is faster but I was pretty happy with my runs as with every run I was getting quicker.
Here are the numbers:
Personal Best for the night was a 15.4 @ 92 MPH with a 2.4 60' I believe.
The car has stock headers, y-pipe, and cat.
Mods are as follows:
Blox filter with velocity stack
HKS muffler
Resonator delete
S-Tech springs
BTW the car is a 5spd manual with the stock shifter with 120xxx miles on the motor. I plan on going back in about 2 weeks after removing the back seat and what not.
Just curious what other 5th Gen 3.0s are running and with what mods.
Old Aug 16, 2011 | 10:31 PM
taz394's Avatar
my friend ran a 14.9 on intake and catback exhaust
tap seems a little low .... and the launch needs a little work unless your tires aren't in that great of shape
Old Aug 16, 2011 | 10:41 PM
QT1 5MT AE's Avatar
Gram Lights addict
you should be able to run mid 14's if launched right given that motor is running healthy
Old Aug 17, 2011 | 07:23 AM
jbrooks870's Avatar
I ended up running out of time but Im sure she will break 14s with some minor weight reduction. As for the trap Im running stock size Yokohama tires with plenty of life, but the tires themselves are garbage for all seasons. They werent hooking as firmly as I would have liked but I didnt lower the tire pressure either.
Next visit Im going to run them around 25psi.
Old Aug 17, 2011 | 07:34 AM
phatboislim's Avatar
i ran a 14.9..i forgot what my 60' was, i think it was a 2.2 or 2.3
Old Aug 17, 2011 | 11:57 AM
SmokinMax02's Avatar
I've seen quite a few 5th gen/3.0/5 speeds run 14.9's bone stock with a 2.2 or 2.3 60', with a trap of 93-94mph. 15.4 seems a bit low considering your mods. You should probably be in the 14.6-14.9 range, atleast. I also doubt removing the back seat, spare, ect will reduce your times by more than a tenth or two. A 2.2-2.3 60', good weather, and a good track should get you around 14.9-15.0 range. Might want to check your knock sensor.
Old Aug 17, 2011 | 01:15 PM
Grand_hustle17's Avatar
i pulled a 15.0@93 with my DE-k auto with ebay cold air and greddy evoII catback ............. nice times none the less, keep at it and im sure u can pull a slightly better time
Old Aug 17, 2011 | 08:02 PM
DrunkenPanda's Avatar
I gotta get out to the track and see what my 01 will do.
Old Aug 18, 2011 | 04:28 AM
i really dont see how the 5th gen can get a 15 sec stock...15.4/15.5 was the stock time when it came out...
i'm pretty sure w/ more seat time i can get a 14.7 in mine
Old Aug 18, 2011 | 06:58 AM
jbrooks870's Avatar
I wana see how fast I can get on stock headers/cats/ypipe. As of now all my mods are minor but the 5th gen is a heavy car which sucks in the 1/4.
Old Aug 18, 2011 | 07:02 AM
i've only been to the track once in this car...best time was 14.9 worse was 15.1...i know i can get better than 14.9 if i stayed at the track, but i just wanted to see what numbers i had just once and let it go. i might go back since i have a cutout..but ill need to get some 17s to go back w/ instead of running these G wheels
Old Aug 18, 2011 | 09:47 AM
jbrooks870's Avatar
True I felt the same the way, the longer I stayed the quicker I was running. I'm running 5.5 gen SE wheels. Once you see your times decreasing it becomes addicting haha.
Old Aug 18, 2011 | 09:55 AM
lol my first time was my best time...
Old Aug 18, 2011 | 11:05 AM
NmexMAX's Avatar
dot dot dot ...
If I hadn't read the title, I'd lol.
Old Aug 18, 2011 | 11:39 AM
:rollercoaster:
Old Aug 19, 2011 | 11:58 PM
MaximaSpd85's Avatar
Make sure your vias is functional before your next track visit. Otherwise keep up the good work and have fun
Old Aug 20, 2011 | 07:35 AM
jbrooks870's Avatar
Chances are I'm going to swap in a manifold with the power rod removed and see what happens. Since there was a 15.4 with an unmodified manifold I'd like to see what a power rod removal will accomplish, if anything.
Old Aug 21, 2011 | 12:45 AM
Just one of several examples of a stock 5th gen 5speed...
http://forums.maxima.org/1-4-1-8-mil...ile-track.html
Pretty good trap man. That's probably a 14.7 with a 2.20 60', could probably run 14.6 or 14.5 with a low 2.1 60' if you're able to pull some really sick launches off.
Old Sep 15, 2011 | 11:05 AM
Nexus67's Avatar
Bumpage;
Check out this old thread (it's a short convo about members taking their new dek's to the track):
http://forums.maxima.org/5th-generat...ack-times.html
OP, get some lighter wheels (if you're willing of course, some folks don't care), you WILL notice a difference though.
CRizz
41
Jun 7, 2021 05:42 AM
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
ef9
Aug 27, 2015 07:21 AM
