1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
14.6 @ 94
Old Aug 19, 2011 | 10:47 PM
7speed's Avatar
14.6 @ 94
No bueno....
Long drive from Dallas, maybe an hour of rest for the Maxi. Racetime at night about 88 degrees, houston humidity.
Excuses right......
02 auto (im spacer, bop plate, jwt pop)
2.25 60 ft
9.47 1/8 @ 76.36
14.66 @ 94.62
Basically I was quicker by .1 with addition of IM spacer. But maybe not fair because when ran that it was 60 something degrees out.
Old Aug 20, 2011 | 08:43 AM
taz394's Avatar
I keep telling ya the DA is horrible at that track lol .... Unless you going just to practice launch ... i don't even bother
Old Aug 22, 2011 | 02:08 PM
7speed's Avatar
Plus I had that lazy auto shifting action from trying to let my car sit so I know I didn't get my true numbers also from that.
But your right I think with DA corrections I would be 14.2 @ 97
Old Aug 22, 2011 | 05:26 PM
aackshun's Avatar
Hrmm... Good thing I didn't go that night, I was @ Houston's real race track Friday night watching a stock 6spd do work on Hondas
Old Aug 23, 2011 | 12:29 PM
7speed's Avatar
Uh uh, I think I know. I might have to hit that up sometime.
But damn I only got to see 3 other Nissans cars I thought would be competition for me but didn't get lined up with them. A black 02 model Altima 3.5 on some 20's that ran 15.5. And 02 model G35 coupe that ran 15.0. New V6 stang ran 15.0 also.
I'm impressed by a lot of those trucks out there running 13's and ofcourse the v8 stangs, camaros, wrx's, srt-4's.
Old Aug 24, 2011 | 01:26 PM
02AutoMax's Avatar
Well looks like I know what time I will be running this Friday. I have the same exact mods but I'm on stock rims so that might make a difference?
How did you launch? I'm not sure the local dragstrip can handle a very aggressive launch so maybe just keep it at idle then slowly put it to the floor?
Old Aug 24, 2011 | 03:40 PM
7speed's Avatar
These are FORGED 19"s lol. Lighter than stock. But yeah stocks should help. And hopefully when you go its cooler outside.
Basically I let the car shift itself. At the launch, I brake torque a little maybe up to 1500 (car won't really let you go any higher) then get off brakes and kinda feel for a little scratch then decide how much to punch. Seemed so much easier when I had stick shift though, was much easier to ride clutch.
If you think track will be similar to street grip. You may just wanna practice launch situations before you go.
Old Aug 24, 2011 | 03:57 PM
NmexMAX's Avatar
dot dot dot ...
IMO, the term Forged & 19" is a semi oxymoron, why go that big if trying to save weight? I even have an issue with Forged 18's. Don't let the sig pic fool you, those are my vanity wheels, just so happens they're forged. When I'm serious about it, I slap on my forged 17's.
Forged 16 & 17's if your brakes support it, now that's where I support forged wheels.
Old Aug 24, 2011 | 06:40 PM
02AutoMax's Avatar
Yeah I have tried launching from just idle before and had a nice peel out through first and a little second.
nmexMAX how much does the weight of the wheel going from stock to say around 18 lbs affect the launch with street tires? Wouldn't it be more likely to spin without drag radials?
Old Aug 24, 2011 | 07:10 PM
NmexMAX's Avatar
dot dot dot ...
DRs are meant to be sticky. Stock SEs are heavy. 24lbs if I recall but less rotational mass helps. 18lb 17s on non DRs will spin. I'd say gind what's best for you for launching. Play with tire pressures RPMs etc.
Old Sep 10, 2011 | 01:43 PM
FlawleZ's Avatar
7Speed don't sweat the times and trap. That's about spot on considering the temperatures and DA. I think with cooler temperatures you could see a 14.5-14.4.
Old Sep 10, 2011 | 02:24 PM
Rhyno02's Avatar
Those 19s are killing you. You need more sidewall and about 20-22 PSI. Those low Pro's look great and help with handling but will kill your launch.
Old Dec 5, 2011 | 09:18 AM
markeddy's Avatar
good slip...
Old Dec 25, 2011 | 04:07 PM
CMax03's Avatar
Originally Posted by 7speed
No bueno....
Excuses right......
2.25 60 ft
9.47 1/8 @ 76.36
14.66 @ 94.62
I'm curious which Houston Track you went too? I've tried the one out in Sealy and it's was hard to launch compared to Baytown's Royal Purple Raceway park (formerly Houston Raceway Park), I've lauched with 2.1/sec/60ft consistently with an intake problem called a INJEN Intake which was suffocating my topend....a still run back to back 14.6 (03 A/T)you could actually hear it bog down after 1000 ft and switching into 3rd gear....
Old Dec 25, 2011 | 09:22 PM
7speed's Avatar
Royal Purple. Never been to the one in Sealy. Nice launch, I can only wish, maybe in the spring when I have some new rubber I can get 2.1.
Old Dec 28, 2011 | 04:33 AM
CMax03's Avatar
I was thinking you went to the track on the other side of Houston (West side) called LoneStar Motorsport park @ the Hennessey shop! The launches suck there I could never hook up none of the times I went there! The elevation is 226.4 ft above sea level.....Those 2.1 /sec/60Ft were with 18" wheels by the way (245/40/18), I had the Progress Sport Springs/Illuminas with stock Motor mounts....I'm running ES MM now and I know it hooks better than before....
Old Dec 28, 2011 | 03:34 PM
7speed's Avatar
No never been there. You will have to let me know when you go back to the track in the spring. By then I'll have my new rubber and should have my ES mm in, plus I'm not on stock suspension anymore so hopefully I can hit 14.4.
Old Dec 28, 2011 | 08:25 PM
Grand_hustle17's Avatar
A 14.4 should be about right if u take th 19's off lol
Old Dec 29, 2011 | 05:28 AM
CMax03's Avatar
If I could wear 15's over my 6th gen front brakes I would try to see how it runs with 15" wheels but I love my sure stopping power!
Old Dec 29, 2011 | 08:09 AM
7speed's Avatar
LOL 14.4 or bust with the 19"s. What I run on track is what I run on streets.
But yeah I wish I would have kept my stockers so I can switch out sometimes.
Old Sep 7, 2012 | 10:34 AM
MrEous's Avatar
^ Jeff™
Kev done got upgraded to an '04 6spd, hopefully driver-mod still works.
See ya there, Kevin
Old Sep 8, 2012 | 06:47 AM
7speed's Avatar
After last night, now I know that my 6th gen is faster than my 5.5 gen.
And that your 5.5 gen is faster than my 6th gen.
Old Sep 9, 2012 | 07:14 PM
Rods03Max619's Avatar
You hit the track, what was the times...
Old Sep 9, 2012 | 08:28 PM
7speed's Avatar
Haha yeah
Sorry 60ft of 2.41 on 2 runs were my best. I couldn't get my launch right so just would go off idle. Plus no way to avoid water box because they sprayed to damn much.
1/8 9.51 @ 77.xx mph
1/4 14.52 @ 97.xx mph
Old Sep 10, 2012 | 08:54 AM
MrEous's Avatar
^ Jeff™
DA calculator shows your time could be 14.0@100mph under best conditions. Aaron showed me this link and it's voodoo magic, but it gives a better feeling. lol
http://www.dragtimes.com/da-density-...ect+ET+and+MPH
Buy that TQ link yet??
Old Sep 10, 2012 | 11:41 AM
7speed's Avatar
No tq link I know of for 6th gen
Its all good. We will go back when it's not 90 deg out and when I don't drive a different car for a week LOL.
What would your time be?
Old Sep 10, 2012 | 12:17 PM
MrEous's Avatar
^ Jeff™
13.879 @ 102.9 MPH
Old Sep 11, 2012 | 04:28 PM
MrEous's Avatar
^ Jeff™
Here's a vid I did get of you...14.6@96, so it wasn't your best
Old Oct 14, 2012 | 06:11 AM
7speed's Avatar
Yeah 14.60.
But hopefully this weekend coming up...........14.3. I know it has it in her
Old Oct 14, 2012 | 05:28 PM
po8pimp's Avatar
damn that other car had you by like 2 car lengths and you still beat it. Pretty good driving.
DoGGy
Tires and Wheels
Jun 2, 2006 05:30 AM
Dave B
Nov 21, 2003 12:25 AM
speedemn
29
Oct 22, 2003 09:50 AM
ga2000
Aug 28, 2003 10:41 AM
bigdo26
29
Aug 21, 2003 08:17 PM
