1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
First time with the max
Old Aug 27, 2011 | 10:39 PM
neonrain's Avatar
She was a trooper. 240 xxx miles and was loving it. Ran a 15.3 (99 SE-L 5 speed) made 10+ passes. had no traction But still had fun. Main problem was wheel hop. can anyone tell me how i can help limit it a bit?
Old Aug 27, 2011 | 11:41 PM
Nealoc187's Avatar
SLOW
you can skip the burnout, it doesn't do anything for you since you're on street tires.
Reduce the tire pressure, and practice using more clutch or less throttle or a combination of both on your launch to keep your car at the limit of traction rather than going over the limit and spinning your tires excessively.
If you do hop, ease off on the gas a bit rather than just powering through the hop.
With all those miles, it is highly likely that most or all of your bushings and motor mounts are in less than perfect shape. Motor mounts and LCA bushings being in good shape will drastically reduce the likelihood of wheelhop.
Old Aug 29, 2011 | 12:37 PM
amixamse's Avatar
A torque link, better suspension, preloading on launch
Old Aug 30, 2011 | 04:09 PM
7speed's Avatar
Pretty sweet. I miss my 96. Auto with no mods ran 15.9, and I know could have been a little better with some better tires.
Old Aug 31, 2011 | 07:16 AM
MaximaSpd85's Avatar
For the wheel hop definitely do as neal suggests and check all the bushings etc, butttt..... Theres always the two strap mod
Old Aug 31, 2011 | 07:25 AM
phatboislim's Avatar
coilovers...didnt have any wheel hop with me when i went...but yea no need to burn out on street tires, just go
Old Sep 16, 2011 | 08:58 PM
315max's Avatar
no need for burnout on street tires?...more like do not do it. the hotter street tires get the more slick they become. avoid water box with all tires. dry spin them when your in the grooves with VHT(if they use it) to get rid of any water and debris
Old Sep 17, 2011 | 07:45 AM
Rods03Max619's Avatar
Nice, I can't wait to hit the track soon....but car isn't ready yet motor mounts are a must for me .....
Old Nov 22, 2011 | 10:38 PM
mrjasonlyrics's Avatar
Tire pressure is important for gripping on the tracks
Old Dec 5, 2011 | 09:17 AM
markeddy's Avatar
nice...
Old Dec 19, 2011 | 06:29 PM
smash's Avatar
good stuff
Old Jan 27, 2012 | 04:16 AM
VincentXero86's Avatar
Ther's a first time for everything
Old Jan 27, 2012 | 02:48 PM
OC_Nooby's Avatar
Like mentioned before, preload the transmission. If you don't preload you will break something very soon.
Old Jan 27, 2012 | 09:13 PM
Grand_hustle17's Avatar
kinda cant wait with the to get down the track again... this will be my 1st as a MT
Old Jan 28, 2012 | 10:56 AM
J2FRESH's Avatar
i agree with the above post for bushings and motor mounts, as well as good shocks can't forget that
preload the transmission??? what does that mean???
Old Jan 28, 2012 | 07:09 PM
ive had that in a thread somewhere about suspension n 1/4 times.... due to very little front end lift it can help a tad with traction
Old Jan 30, 2012 | 07:19 AM
OC_Nooby's Avatar
Basically your hand brake is engaged (you holding it so its not locked in) then while your in first gear start slipping the clutch until the car feels like it wants to move (giving it some gas to do so, keep the gas constant). You will notice the cars front end start to lift.
HOKUSMAX
Nov 13, 2017 04:34 AM
MaximaRaj
27
Oct 2, 2015 07:31 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
erictown
Aug 20, 2015 08:01 AM
Balkins
Aug 12, 2015 06:39 AM
