squeaking engine
squeaking engine
my engine in my 87 max is making squeaking noises, at idle and during driving, and also at start up when its very cold, and during turns. someone told me that the belts are worn and are strecthed and need replacing anyone know what to do.
Dave
Dave
Sounds like the belts. The description you gave points to that. So basically, buy new belts. There are 3 of them, crank to power steering, crank to A/C and A/C to alternator. Replacement isn't too shabby. Probably about a good 30-45minutes to do since you have to get to them.
S
S
A standard metric socket set will suffice fine...however, for the upper tensioner, for the A/C, it'll be easier if you have at LEAST a 6" extension, if not longer... IIRC, they are all 10mm, but I could be wrong...
James92SE
142
01-02-2024 09:23 AM
