87 Won't start
87 Won't start
Just got my thermostat replaced and now it won't start! Brought it back to the mechanic and they replaced the spark plugs ($75) and it started...once. They say I may need a new fuel regulator (and that it is just a coincidence that it started happening after the 1st repair). Any other ideas?
I had this happen with a beretta I used to have. Had a compressor replaced and the car wouldn't start the next morning. Said that the reason the pump went bad was the timing belt was about to break and that is why the car wouldn't start now! How stupid is that? They actually expected me to believe them.
I got out the chilton's manual and traced every vacuum line and every wire in the engine compartment. Turns out they had deliberately loosened the main line to the coil packs. It ran until I got it home and on the way vibrated loose enough to not let it start the next morning.
When I accused them of it they hung up. Two months later they were in the paper for fraud.
Glad they got their's
speakeraddict
speakeraddict
One thing I forgot to mention was that (when it does start) it hesitates from a dead stop, but otherwise seems to run fine. Also it seems to start more easily when it has been sitting for a while.
keith_u, that's similar to what I was thinking. They did replace a electrical lead to the fuel regulator and a small vacuum hose.
cardana, I thought of that too but the terminals look good.
speakeraddict, these guys are supposed to have a good rep, (but it only takes one bad mechanic...), I think in this case that it is more inexperience (with Nissan) than fraud, but if they try to charge me much more I will make sure to let everyone know of my experience.
More likely they moved the harness around going to the Head Temp Sensor and now its not making a good connection . They are bad for corroding and once touched will not make good contact anymore . Its right there where they were working yet not really there fault if its corrode . I dought your regulator is causing your car not to start .
Check the Head temp senosr and harrness and replace both if corroded . It buried and inda of a pita to replace with out the right tools .
Originally Posted by spddracer
More likely they moved the harness around going to the Head Temp Sensor and now its not making a good connection . They are bad for corroding and once touched will not make good contact anymore.
Yeah, a CHTS can do that...and when you were in there moving things, you MAY have gotten a better connection than it had, hence the better running, etc...but still not a proper conenction, resulting in the persistant miss and stumble...
Mine would not start after I replced the thermostat...cept my problem was bad wire connections. I dont know why but the previous owner had the main harness connected with pluming tape. I would shake the harnes and it would start. I doubt this is your problem since it sometime starts. Mayve they gapped your plugs bad?
97_GXE
09-15-2015 06:47 AM
QueensMAX
09-15-2015 04:14 AM
markevans999
09-10-2015 04:29 PM
trungg86
09-04-2015 04:58 AM
