Checked ECU today and got 'ignition signal' code
Old Sep 16, 2004 | 08:50 AM
(_8*(l)Homer's Avatar
So, I removed the screws holding the ECU and checked codes. I got code 2,1 or ignition signal. What does this mean and how do I fix it?
-Joe
Old Sep 18, 2004 | 11:18 PM
Someone must know what the code means.
Old Sep 18, 2004 | 11:33 PM
maximase86's Avatar
I love lamp.
When you we're check this was the car running? You might want to try turning on the car during the check and see if it still shows that code.
S
Old Sep 19, 2004 | 09:50 AM
I'll try that.
Old Sep 19, 2004 | 10:32 AM
Drjmaxx88's Avatar
21 is Ignition signal missing in primary coil. I have the FSM for an 88 maybe it can help. Whats the car doing?
Old Sep 19, 2004 | 02:48 PM
The car really isn't doing anything wrong that I can tell. Rough idle and hard starts from sitting 6hrs or more. I have the 87 FSM, but I have found nothing regarding ECU codes.
The car surges when just the tranny is moving the car... You know, when my foot is not on the gas or the break. It kinda jerks forward.
-Joe
Old Sep 20, 2004 | 08:03 AM
Drjmaxx88's Avatar
Sounds like an air intake leak. Mine use to do that.
Old Sep 20, 2004 | 02:12 PM
From where was the intake leaking?
-Joe
Old Sep 20, 2004 | 02:38 PM
Drjmaxx88's Avatar
The part thats black with vulcanized rubber, it has a hole for the crankcase ventilation. It connects the TB to the AIV. I just bought two couplers and a tube from autozone and replaced it.
Old Sep 20, 2004 | 06:54 PM
arsonist63086's Avatar
from my experiance, i had the same problem with my car i checked it out and it ended up being the timeing was off. and adjusted it and it whent away. it came up cuz because of the igniton signal coming from the distrebuter isnt right. the leds and the disk holes arnt lined up right.
but u dont have to take my word for it.
Old Sep 20, 2004 | 09:23 PM
I'll check the intake thing Tuesday.
How do I check/adjust the timing. I can probably borrow a timing gun from Napa or something.
Old Sep 20, 2004 | 11:00 PM
Niku-Sama's Avatar
good luck with the timing, its hard to get the gun down right on top of the marks if you have cruse controll
Old Sep 21, 2004 | 12:07 PM
damn i know how to do it but i kinda suck on explaning things. but i try my best.
1/ get a timing light (ther r 2 typs base timeing and advance timing light. the dff. is that the advance timeing light has a numbers on it and a bite harder to use and more expensive) so just stick with the base timing ligh in other words the rageler 1.
2/ hook up the timeing light (red clap to + of battery and black - of battery the lasy clamp hook up the the #1 spark plug, cabe just clamp it over the cabel)
3/when u open you hood look at the bottem of it the should be a yello sticker that will show u your timing and vacume diagram
4/ look at were it says timeing. the timing will be 15* btdc on a manual and auto it will be 20*btdc.
5/ look for the crank pully (the 1 wich drives all the belts)
6/ once u have lokated it turn the car on and point the gun on it u will see a arowe like ting right on top of the crank pully and littel marks or scars on the pully(tos r your timeing mark.
0 10 15 20 25 30
ll ll ll ll ll ll
engine spins -->(clock wise)
7/ the littel arow like thing should be pointing right over the 20* mark and when u give it gass it should go to the 0* mark automaticly.(that good timeing)
8/ if not right timeing lossen distributer bolt,(size 10mm) and rotat the distributer clock wies or counter clook wise till the pointer is right on top of the 20* mark.
ther i did my best
sake1bs
Sep 19, 2015 09:32 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Trin1j23
Aug 12, 2015 08:31 PM
maxima297
Aug 3, 2015 12:50 PM
