Help with Stanza TB
Help with Stanza TB
I just recived it about 5 mins ago , Now this one is a little diffrent the the stock tb
Im going to have to buy some new hosing to install it because the stock hosing is to short , now in the picture below , the stock tb has another place where you connect a little hose , Its just like the red one but on the stock tb there is also one where i have circled in blue , What shall i do about this? , And for the bigger connecters They are for the 2 same coolent hoses right as on the stock?
Originally Posted by dtm88na
Do you mean that you have an extra vacuum line with no port on the TB? If so, I would buy a tee and tee into an existing line for the vacuum source and just use that instead of a port on the TB.
thats what i did but make shure to get the full effect that you hone out the intake manifold so that it matches the tb properly and also make shure it is smooth...
seems to be a vaccum, It runs up around umm uhh some thing? haha , So what your saying is get a little t connector , That i plug both of the hoses into , and plug the end of it onto , That one place on the tb?
Yeah get a T connector, find an existing line close enough to the line without a port on the TB, cut the existing line you found, insert the T and use the extra port on the T for the line that doesn't have a spot on the TB.
Originally Posted by DJ Technischer
card could you help me out?
sorry i dident mean to post on this one I ment to post for help on whats happening when i drive the car , I have every thing installed , Well i did till i put the stock back on , And for the extra hose i took a t fitting and pluged both little small vaccum hoses up and pluged them into the same port.
lowpost99
Sep 8, 2015 05:06 AM
sanmaximo2000
Oct 17, 2003 03:49 AM
