Always Sometin'!!!!!
Old Aug 6, 2006 | 07:53 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
ok today i started the max it runs fine it was in a slumber after i ported the heads, replaced the gaskets, replaced the exaustmanifold studs(50 buxs from nissan for 12 w/50% disc. bout 3.80 a piece!!!!) now when i start it i let ir run and then it goes for a while and i get smoke coming from the exaust manifolds both front and rear it gets to the o2 sensor and im guessing thats what is making the engine die down a bit not as if its dieing but just a slow down i havent taken it out for a drive yet fearing that it will shutoff at a light or sometin, anyone kno what this smoke is and where it is coming from(White not blue) i dont think that it can be a coolant leak because i used sealant and torked down the heads to spec (22lbs, loosen, 44 lbs) i dunno but i hope someone can help me so i can take it to get it smogged by this week and then ill be on the road thanks...
Old Aug 7, 2006 | 11:07 AM
kiwikev's Avatar
did you use any kind of sealant on the gaskets?
Old Aug 7, 2006 | 06:31 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
yeah
it was leaking before the sealant thats why i used it that permatex copper stuff
Old Aug 7, 2006 | 09:03 PM
kiwikev's Avatar
is the smoke coming from out of the exhaust or is it just something burning off the surface of the manifolds?
Old Aug 8, 2006 | 08:19 AM
maximase86's Avatar
I love lamp.
Have you checked for coolant loss or any other leaks around the motor? Leaky valve covers?
Old Aug 8, 2006 | 05:46 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
when i took off the manifolds the second time it looked like it hd coolant in the manifold covers as for leakt head covers i dont think so....
Old Aug 9, 2006 | 12:09 PM
kiwikev's Avatar
did you use a new intake manifold gasket?
Old Aug 9, 2006 | 04:45 PM
karkev's Avatar
Big-E Dog, that thing is sharp ! I have a 1987 black Max that's gonna have to have a new power steering pressure hose and I was wondering if you had replaced yours ?
Are they difficult to replace and are any special tools needed ?
The space sure looks tight.
I don't mean to hijack your thread but it sounds like you know your way around the Max V-6 engine bay !
Thanks !
Old Aug 9, 2006 | 04:58 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
it took me 6 hours in my 85 on jackstands with a 24mm sosket use a breaker bar and a 6-10 inch extension when i did mins i didnt have a breaker bar that mofoin nut is TIGHT as he11 then take off the other nut make sure the car is cold or youll burn your self MANY times cuz itsd sooo tight back there abd dont loose those crush washers or better yet use newonoes i didnt and i had no leaks also refil up with atf fluid dexron 3 w/mercon (same stuff in an auto tranny)
Holla
Old Aug 10, 2006 | 05:47 PM
karkev's Avatar
E-money thanks !
Ya scared me a little but I gotta do it and I appreciate the good tips !
Thank ya, Sir !
Old Aug 10, 2006 | 07:20 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
youlll be fine
and there was coolant loss before i drained 2 1/3 gallons then i re drained it and i got 1 and 2/3 coolant it was oozin somewhere and oozin a lot but i removed the intake plentium down to the heads and now im gonna replace the gaskets there (the old ones are new) with a new set and hope for the best...
Old Aug 11, 2006 | 08:17 PM
Mr. Blue Sky's Avatar
interesting, is that because it is a little thicker than the power steering fluid or what is the reasoning behind that? Well in any case, I am still using regular old power steering fluid and the power steering doesn't leak and feels nice and smooth (may be due to good maintenance and prior replacement of everything by old owner)
Old Aug 11, 2006 | 11:35 PM
Yayomax's Avatar
still brewin'
Actually my 2nd gen all of a sudden just started smoking really bad for like a week last summer. I lost a few nights sleep cause I thought my baby was done for. There were oil drips on the front exhaust manifold heat shield but I couldnt locate the source. It turns out my valve cover somehow was not tight. Tourqued it down and nary a problem since
Old Aug 26, 2006 | 09:07 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
well with further tests and research its not the head cover but the head itsself its leaking antifreeze into the combustion chamber through the runners. the vg30e has 2xx,xxx miles and needs to be retired but i will keep the body...... ne one in the sandiego area have a engine crane that i can borrow in like a week?
Old Aug 26, 2006 | 11:08 PM
maximase86's Avatar
I love lamp.
Didn't you just port the heads? Sounds like you cracked a waterjacket.
S
Old Aug 29, 2006 | 03:58 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
prolly just a good reason to get a turbo swap and it is coming in a few weeks ill keep yall posted
btw does ant one wanna but some 85-86 headlight covers
i also have a bixenon headlamp setup w/ fog and wiring harness setup for 150 shipped offered to some but no return call....
no ballasts or bulbs
Old Aug 29, 2006 | 09:57 PM
can you post some pics of the headlight covers or pm them to me?? are they clear or smoked? probably would have taken those bixenons off ya if they would have come ready to put on an 85-86. oh well, still waiting for my hookup
Old Aug 30, 2006 | 04:00 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
theyre clear and in a garage 30 miles away but i can get them this wekend also you gan just buy a grill from an 87-88 and itl be good enough
Old Aug 31, 2006 | 08:32 PM
Niku-Sama's Avatar
have you ever thought of taking an old set of covers and making a mold out of them to make your own set of clear lenses?
would eliminate your flat and i know theres gotta be werid gaps and wind noise with those things
Old Sep 26, 2006 | 06:43 AM
MAXI BLUE 03's Avatar
that is pretty cool.
Old Sep 26, 2006 | 05:22 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
thought about it but i need some kinda plastic that i can melt and reuse any suggestions
Old Sep 26, 2006 | 11:12 PM
Niku-Sama's Avatar
they make a cast resin thats clear but its kinda brittle
theres also the same type of thing but in an acryulic but its kionda the same, i'll try to elaborate more tommorow ehn i am not so things...yea tonnorow
Big_E-Dog
28
Aug 6, 2009 11:34 AM
Big_E-Dog
May 8, 2007 09:18 PM
Big_E-Dog
Mar 8, 2006 04:22 PM
Big_E-Dog
47
Nov 14, 2005 11:29 AM
