my horn doesnt work....
Old Mar 7, 2002 | 10:37 PM
max ppower
my horn doesnt work when i push the steering wheel. but when i tested the security, it still went honkin away. any ideas on how i could fix it? thanks
Old Mar 8, 2002 | 10:21 AM
John L's Avatar
Horn...
Hey, Max, stuff like that is constantly happening to my LBCs. All I can suggest is, trace the wire, if you don't find anything wrong, run a new one, if that doesn't fix it, start all over.
Old Mar 8, 2002 | 01:26 PM
avalon42's Avatar
Yep, if you run new wire and still have the same problem, check the relays.
Old Mar 8, 2002 | 07:03 PM
max ppower
Re: Horn...
how do i get to the wire
Old Mar 8, 2002 | 10:59 PM
alllw86's Avatar
Re: Re: Horn...
Max, there is only one horn relay, both the horn switch on the steering wheel and the security system works off of it. Since you say the security system does get ah-going, you should now check the wiring at the steering wheel.
Remove that big horn buttom in the middle of the steering wheel. Behind it is where the horn switch will be, find the wire that goes from the switch to the horn relay, should be a single wire. You can test it by grounding that wire and the horn will blow, use a jumper if you have to. If it doesn't sound off then there is a break somewhere to the relay.
AL
SmoothMax
Apr 29, 2001 06:24 PM
MrBurner
Jan 19, 2001 08:22 AM
MaineI30
Oct 9, 2000 08:30 AM
amixam69
Sep 16, 2000 11:06 AM
