VG30DE compression/internals?
Old Jul 26, 2002 | 04:41 PM
Dummy's Avatar
anyone know the stock compression on the VG30DE? and if the block used in vg30de's was mounted with vg30e heads would it effect the compression? in other words are the internals the same?
Old Jul 26, 2002 | 07:40 PM
Nismo87SE's Avatar
Re: VG30DE compression/internals?
So are you going to order the VG30E heads that were made from 5/88-4/89 for a z31 from a nissan dealer? Otherwise your VG heads won't fit because they are different. 30E heads on a DE would be a waste of $$ and time. VG33E should be done instead.
Old Jul 26, 2002 | 09:04 PM
Dummy's Avatar
no, i was wondering because i might purchase a max which the owner said he replaced the block with one from a vg30de.
i had planned on buying the vehicle for a project, and was just curious about the differences if any.
Old Jul 26, 2002 | 10:42 PM
surfermax92's Avatar
Nismo, what parts would need to be different on the vg33e that could otherwise be used on the vg30e? I don't want to have too many custom parts made, so I was attracted to the idea of using parts from the vg30de. If the only difference between the vg30e and the vg33e is the bore of the pistons, then I may consider building the 33. Thanks
Old Jul 27, 2002 | 09:02 AM
Cincy94Max's Avatar
Someone posted a little while ago that the VG33E engine has a different mount of sleeving than the VG30E that would allow you to bore the VG33E out even more. Thus you could bore out the VG33E more than the VG30E because of the sleeve material and thickness. Sounds plausible, but it could just be hearsay.
Old Jul 27, 2002 | 06:25 PM
Nismo87SE's Avatar
I don't believe the VG33 is really any bigger in width than the VG30. The VG33 has different sleeves thus giving the bigger displacement. Is this for NA or boost? The only thing that can be interchanged is the bottom end (crank, rods) and the cams in the heads. There isn't really any need to use a 30DE block when you can order the factory rods + pistons from a VG30DE for the VG30E. Now the VG33 is going to need custom pistons if you high compression or you can order the pistons from the supercharged frontiers for boost.
Old Jul 27, 2002 | 06:35 PM
Dummy's Avatar
so does anyone know the compression of the DE? im pretty sure the blocks arent EXACTLY the same seeing as the vg30e is a 2.96l and the vg30de 2.98l or am i just a dummy
Old Jul 27, 2002 | 08:44 PM
mtcookson's Avatar
10.5 : 1
Old Jul 28, 2002 | 10:25 PM
Cincy94Max's Avatar
Has anyone researched the motor mount positions of the VG33E compared to the VG30E. I wouldn't mind just dropping in a supercharged frontier motor, even though hood clearance would be a large problem.
Old Jul 29, 2002 | 12:56 AM
Nismo87SE's Avatar
The VG33 has simular mounts just like the VG30 does. The supercharged VG33 won't fit unless you have a hood with a hole in it. It would stick out like some of those hot rods do. The regular VG33 would go nicely with a T3 from a Z31. With headwork + turbo cams it would make 250-270whp easy, where as the VG30 would struggle to get 250whp.
Old Jul 29, 2002 | 09:20 AM
mtcookson's Avatar
would you have to lower the compression of the vg33 to turbo or is it pretty low?
Old Jul 29, 2002 | 10:11 AM
mykizism's Avatar
depends on what u want
Old Jul 29, 2002 | 10:15 AM
mtcookson's Avatar
well... i'm wanting to do the vg30et swap but it sounds like the vg33 is better to use. i think i'll just stick with the 30 though because it will be less of a hassle.
Jeff92se's Avatar
I'm needing a caw
600hp
Old Jul 29, 2002 | 10:43 AM
Lordrandall's Avatar
Originally posted by Jeff92se
600hp
No problem, 500 shot of NOS should do it.
Old Jul 29, 2002 | 12:12 PM
mtcookson's Avatar
500 shot?!? my engine pulls 160. the vg30et pulls 205, i would only need 395 shot... duh!! but you guys can give up on the 600 hp stuff now... i'm not that dumb anymore... mostly...
Old Jul 29, 2002 | 12:34 PM
You want 600 HP crank or Wheel HP?
Old Jul 29, 2002 | 01:08 PM
Nismo87SE's Avatar
Not if the engine is tuned properly. It runs 9.0 CR stock IIRC.
Old Jul 29, 2002 | 01:39 PM
mtcookson's Avatar
thanks for the info.
uh... i think i would have to go with wheel horse power
Matt93SE
May 24, 2019 02:58 PM
93maximaguy
Jul 3, 2009 03:13 PM
915spd
28
May 2, 2004 07:18 PM
Nismo87SE
Jan 14, 2002 02:56 AM
Nismo87SE
Sep 14, 2000 11:41 AM
