can I still pull codes from the ECU?
I've searched and found pretty good directions at getting out codes from my ECU, but there's something I'd like to clarify before I go try it: I am getting terrible fuel mileage and I think a sensor (knock or O2) is going, but I am not getting a check engine light. Does the ECU give some error codes without the check engine light coming on when driving? Or would I be wasting my time to mess with the ECU if I am not getting a check engine light?
It wont harm to check
I wasn't getting any engine check light.
I got the FSM recently. So I set out to try couple of things in the FSM. One of the things I did was to check the trouble codes from the ECM.
I checked the LED on the ECM. I read code 33.
Surprisingly I was't seeing the Engine check light on during normal run of the Car.. I am getting around 23-24 miles per galon.
I think it is decent. But code 33 is a indication fualty O2 sensor. I have to check the O2 sensor
If there is no problem then the ECM will read 55 on the LED..
So if you have the FSM it is easy to check the codes from FSM..
Hope it helps
Hope it helps
Re: It wont harm to check
Hope it helps
Hope it helps
Hope it helps
Hope it helps
Re: Re: It wont harm to check
As long as you didn't disconnect the battery, you can read whatever codes are stored in the ecu. The engine light doesn't have to be on for the ECU to have already stored a code.
i_canoe - FSM means Factory Service Manual, it's the book nissan writes about your car describing how to do everything to it, step by step. Get one.
Re: Re: Re: It wont harm to check
Also, yes FSM = factory service manual, and I've got dibs on the one for sale on eBay right now that ends in 3 days!!! Please let me have it!!! I really need it!!! :-D
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
