91 SE behavior
Old Sep 22, 2002 | 09:53 PM
hli's Avatar
hli
91 SE behavior
I just got this car (91 SE) and I am trying to get use to the car.
When I accelerate to a certain speed (example: 15mph) and release the accelerator the car seems to maintain that speed at level ground. Only when I hit bumps, go up hills or tap the brake will the speed of the car be reduce to a lower speed but becomes constant at the lower speed when level ground is reached again. I do not have the cruise control on and this happens at low speeds (< 30mph) also.
I can not remember if the RPM drops after the accelerator is released.
Am I just nuts and what I am noticing is just the car's ability to coast further than the other cars I am use to?
Or do I have a problem?
When at "park" the engine will rev up when the accelerator is pressed and immediately drop when I release it.
Old Sep 23, 2002 | 12:30 PM
wyskibumm's Avatar
Re: 91 SE behavior
ground level is reached again? So let me get this straight, your car goes airborn, when you hit the accelerator?
Old Sep 23, 2002 | 03:11 PM
nismo-max500's Avatar
i bet your throttle is sticking
Old Sep 23, 2002 | 04:14 PM
hli's Avatar
hli
Re: i bet your throttle is sticking
If the throttle is sticking the test I did when at park will leave the RPM high when I release the accelerator?
I'm going to try to test the TPS and look at the ECU code.
Any other sugguestions?
Originally posted by nismo-max500
Old Sep 24, 2002 | 12:55 PM
1993MaxSE's Avatar
its just the auto
Well I've never driven an auto until I had to drive my mom's Taurus once last year, and I noticed the same thing. Since there's no direct compression slowing the engine (and car) down like when you take your foot off the gas in a stick-shift, it just coasts forever. It's so annoying! So if you're used to manuals, and it's an autp, thats probably why. It's not a problem just another annoyance of an auto.
05RLS2
Sep 27, 2015 09:24 PM
Maxima30
Sep 7, 2015 06:13 PM
JMag90
Aug 25, 2015 09:17 AM
chris j vurnis
Sep 9, 2002 10:02 PM
hlh0501
Jun 28, 2002 03:06 PM
