Intermittent stall on acceleration 92 Maxima
Old May 16, 2003 | 11:41 PM
  #121
DaBoxSE's Avatar
Again, Try checking the Throttle Position Sensor. It is what caused my 93 VE to fall flat on its face randomly as well. There are many things that can cause this problem, just make sure you check them all.
Old May 17, 2003 | 12:08 AM
  #122
sukoshiyoshi's Avatar
I'm just another maxima with this problem. But only happens when the engine is cold. I have no problem up-shifting (automatic) from 1st to 2nd but from 2nd to 3rd.......it just starts to high rev and hardy move at all. I can pop it into second (on shifter) and get power once again. It eventually revs back down and up-shifts to 3rd. After that I don't have any problems. Weird. Everyone is talkng about sensors, and stuff. Has anyone checked their trans before? Just curious. Kind of may seem like a trans problem to me. But then again I really don't know so that is why I am trying to get ideas from you guys.
Thanks ahead of time.
Old May 17, 2003 | 09:59 AM
  #123
Ekote's Avatar
Another update. Took it out on the road this morning and the idle stutter came back. It does seem to do it during acceleration. Very strange. I think I will try the Throttle Position Sensor next. Is there a way to test it or do I just need to replace it?
Old May 17, 2003 | 10:08 AM
  #124
Ekote's Avatar
I found these (http://www.partsamerica.com/SelectPa...osition+Sensor) Throttle Position Sensors on Schuck's website, but they all say they are for 'AT'. Any suggestions of a parts site? THanks.
Old May 17, 2003 | 02:44 PM
  #125
acidspit86's Avatar
does this happen on 91 maximas?
Old May 27, 2003 | 06:16 AM
  #126
Ekote's Avatar
I ordered a Throttle Position Sensor from Schuck's for about $53.-. I'll be getting it and installing it in a few days. I'll keep you posted if it works.
Old May 27, 2003 | 03:13 PM
  #127
heat23's Avatar
for the past few months my 92 Maxima GXE has had some engine problems.... The RPM meter will drop down to 500rpm, then bounce back up..this happens right when u turn on the car, or at a stop light...and whenever this happens the car shakes...
in the past few weeks, the car stopped accelerating at up to 30 mph or so...its VERY slow accelerate, theres no way to go up an overpass without losing speed...
so 2 days ago we changed all the spark plugs...this had seemed to fix the acceleration problem....but then yesterday when I took it for a drive, it started to give the same problem...
are these 2 problems related?? any ideas on what to do? How do you disonnect the O2 sensor? And do you see those error codes?
thanks
Old Nov 3, 2008 | 03:18 AM
  #128
lydemxma's Avatar
I have gotten rid of my 92' SE since my last post. I went through the entire system in search of my problem: Mass air flow, crank angle, O2, coil, plugs, ECU codes, fuel pump, fule filters, Nissan, blogs, etc... I did find a solution. GAS- my SE was VERY sensitive to gas, and at the time I was burning regular and mid-grade. I started burning premium, and every now and then add some booster to a tank. Went away for good. At least that's was my situation. Although I no longer own the 92' I sure do miss that 5spd that would go 145 on any give day!
Old Mar 9, 2012 | 12:15 AM
  #129
steveblymyer's Avatar
stalling...
After running voltage drop tests across the primary side (power and ground) of the coil packs, I found the ground wire (black wire coming from each of the coil pack connectors) has very high resistance which will cause the plugs to fail under load. (when accelerating). The remedy for this would be to replace the old ground strap with new 14 gauge wire. Hope this helps
Old Mar 9, 2012 | 09:36 PM
  #130
maximo018's Avatar
yeah sounds like you need a grounding kit
Lakersallday24
Nov 7, 2024 07:31 PM
Finkle
Sep 27, 2015 09:53 PM
Bruceharrison
Aug 9, 2015 07:56 AM
Gsantos79
Aug 8, 2015 07:41 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
