Arg, having some trouble. kind of long
Ok, i'm having some trouble with my car and I need some ideas from people.
I have lost tons of gas mileage. I have no clue why, i just all of the sudden started to get worse gas mileage than i used to. I used to be able to get about 130 miles in a quarter of a tank when full. Now i can only get 80.
I seem to have lost power. It just all of the sudden doesn't seem as fast as it used to be. I have a cone intake (some crappy one from auto zone that costs 15 dollars) I did a type of short intake setup. I twisted the batter so now the filter is in front of the batter right behind the headlight. I have a Magnaflow muffler with 2.25 inch cat back piping (but with crappy pressure bends). When i punch it my intake sounds like it being restricted really badly. I am thinking i am loosing performance and gas mileage because i hear a really bad exhaust leak in the front somewhere (probably the dang studs which i know a pair are broken). Could a bad leak in the manifold be causing this? Please help. Thanks.
no, can't be that. i have vg. i just recently changed my oil and put some slick 50 engine treatment in there and changed my plugs but not much changed. i did notice it ran a little smoother when i changed the plugs but still having the same trouble.
i think a motor/tranny mount may be bad. when i shift at low rpms from 1st 2nd the thing hops around like i'm driving at 700 rpm in 4th, whereas when i first got the car i could shift at 2000 rpm and it would just drive like normal.
thanks for the info. i'll try the timing and egr stuff. i don't really know what pinging or detonation sounds like but i'm sure if i heard it i would be able to tell and i don't hear any abnormal sounds. i only run 92 or higher octane gas in my car so i know it won't ping from the type of gas. i have a crappy motor mount from my gxe (had a new one put in) so i'm going to try making a solid polyurethane mount with that. again, thakns for the info. i'll go try it real quick.
sweet. that's it right there then. i'm hearing a bad exhaust leak (right after my muffler was put on too) so i'll do down there and ask them if they can find it. more than likely it's my broken studs though
Originally posted by RosenKen
Exhaust leaks will really hurt gas mileage. When my stock y-pipe was leaking, I got about 260 miles off a tank. Now with a WSP Y, I regularly see 360 miles per tank!
Originally posted by male
I hate those damn studs. Make surre you use the turbo style ones when you replace them. In fact, when I ordered mine from Brown and Brown nissan in Tempe AZ, I forgot to specify that, but they sent them to me anyway. Just a heads up.
It doesnt matter if you order the turbo studs or not since Nissan has upgraded all their new parts to stronger materials. So if you order regular exhaust studs for your car you'll get the upgraded studs.
LUV4DSC, sounds like you need some help dude! Fix the gas issue first..that's a drain on the wallet..tune that **tch up. Then take the money you would have been spending on gas and start fixin gthe other crap. Good Luck
so far egr is fine. i need to check timing now. i did find out my pcv valve wasn't hooked up correctly so now that is fixed. not sure if that will really do anything though. does anyone know what that piece is on the top right of the intake manifold (if you are looking at it from the front of the car) when you give the engine gas that thing is supposed to move, mine doesn't. will that do anything?
wouldn't the CEL turn on if it was O2? i can't believe i didn't notice it but what happened on the pcv this is the hose cam off of the intake so it was sucking in normal air and i have no clue what the hose from the valve cover was doing being unhooked like that. hopefully nothing got ruined though.
dead O2 = light
you might have a lazy one.
Just going by some past info, plus the baggies they came in said turbo style, so I just assumed they were beefier.
06-06-2017 02:01 PM
magiconthetire
10-26-2015 09:03 PM
MaxLvr21
10-17-2015 12:11 PM
maxima297
09-30-2015 03:32 PM
