Problem with 1st gear
Old Oct 30, 2002 | 10:07 PM
kaleb's Avatar
When I rev the engine to 4,000 RPM from a stop and let go of the clutch pedal with the car in 1st the wheels just spin and make loud sqealing noises. Does anyone else have this problem? Could my axles be bad? Could the problem be that I removed that cylinder thing in the trunk?
Old Oct 30, 2002 | 10:16 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
possibly a clogged O-pipe or a blown gasket on your Vtec solenoid....thats what happens when you use Jeff's bubblegum gaskets!!
Old Oct 31, 2002 | 01:12 AM
mykizism's Avatar
i think i have a malfunction with my VTecH Solenoid too.. every time i rev my car to 8K rpm's My Boost gauge reads 15Psi, its suppost to cut off at 12Psi.. its creeping on me
Old Oct 31, 2002 | 08:15 AM
DaBoxSE's Avatar
Have you replaced your spark plug fluid recently? That might be it?
Old Oct 31, 2002 | 08:30 AM
tilt's Avatar
Rev the engine til you cant go any higher, put it in 5th gear, drop the clutch. You might smell something burning from the engine compartment but don't worry, it's just a minor side effect. No more squeeling, problem fixed, pat yourself on the back.
Old Oct 31, 2002 | 08:45 AM
DanNY's Avatar
Ad·min·is·tra·tor
your problem is that you're revving too low...needs 5000rpm.
Old Oct 31, 2002 | 10:59 AM
Sudesh's Avatar
Slightly off topic..
I used to have a problem with my clock fading in and out. So i went to an ASE certified mechanic (none better). He said when you see the clock fading in and out like that, most likely your timing chain is worn, so it won't be able to keep the time properly. Had that sucker replaced immediately.
Now when people ask me the time, I let them know and smile to myself knowing that they've been properly informed.
Old Oct 31, 2002 | 11:36 AM
Agamemnon's Avatar
Your front wheels are too small and can't handle the torque. Replace with monster truck tires.
Old Oct 31, 2002 | 11:59 PM
Delvin's Avatar
Re: Problem with 1st gear
I have the same problem as well. I hopped into this Honduh Civic with shiney stuff and stickers and white rims and it didn't do it, even at 6500rpm. I need to find the source of this problem with my car.
Old Nov 1, 2002 | 02:04 PM
mykizism's Avatar
Re: Re: Problem with 1st gear
no your car is fine..its suppost to do that
Old Nov 1, 2002 | 07:28 PM
poorcollegeboy's Avatar
i only have that problem when i drive with that lever on my right pulled up.
i think that lever is for fuel economy b/c my car doesn't feel as fast with it up. it's sbroken though b/c i get worse gas mileage.
Old Nov 1, 2002 | 07:34 PM
mtcookson's Avatar
are you being serious? the tires are supposed to squeal or are you talking about some other squealing sound?
Old Nov 1, 2002 | 09:49 PM
mykizism's Avatar
haha go back to nissan X
Old Nov 1, 2002 | 09:51 PM
mtcookson's Avatar
uh.... ok
i wasn't sure if the guy was making a joke or not. if he wasn't you guys are just being a bunch of asses, it gets really tiring seeing people tear others apart like that. that's what my little brother does. he is in junior high. i'm pretty sure most of the people on here are a lot older than that.
Old Nov 1, 2002 | 11:43 PM
Matt93SE's Avatar
STFU n00b!
Here bud.. have a big ol' helping of LIGHTEN THE HELL UP!
Old Nov 1, 2002 | 11:45 PM
mtcookson's Avatar
why doesn't everyone else lighten up though?
Old Nov 1, 2002 | 11:47 PM
KLoWnPR109's Avatar
what you talkin about willis?
Old Nov 1, 2002 | 11:51 PM
mtcookson's Avatar
i dunno... it's 2:50 in the morning and i'm trying to get pictures of my turbo engine put on here so i can proof since everyone likes that
Old Nov 3, 2002 | 03:15 AM
RosenKen's Avatar
Man I got the same exact problem, except when I do it, the car doesn't even move for a few seconds and smoke starts coming from the front of the car... it scares me! I've been trying to figure this one out for a while, I think I'll change my fuel filter, that might fix it. Anybody want to send me detailed step by step directions for that?
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
wingnut2006
Sep 19, 2015 06:13 AM
slowlifer
Sep 8, 2015 05:53 AM
