Why a VE knock sensor goes bad
Check out this corrosion I found! If you look closely, above the left terminal on the sensor, there is a white dot. Right through the dot is a crack. There was also another crack along the side of the sensor. Knock sensors should be considered regular maintenance items just like an oxygen sensor. Mine never sent a code but you can bet that corrosion sure didn't help things.
The new one is in and it's running, but I only drove it the 2 miles home and didn't have a chance to really test it. I wanted to make sure all the gaskets were sealing too before I got on it. Overall impressions are good, seems like the torque band has fattened up across the rev range.
I'll report later about whether it worked to fix the "heat soak" problem. I'll also be doing a write up on how to replace this. Overall it wasn't anything extremely difficult, just time consuming and tedious in parts.
![](http://members.aol.com/_ht_a/rosenken/images/badKS.jpg)
Originally posted by MaxHeadroom
thats what the knock sensor looks like on a 93? That looks more like the one on the 95 and newer.
Naw there are a few different ones. But in that don't look like the one for the 91-94 ve. It looks like the one for the 95-99. Where was it located on the engine, under the plenum or under the manifold?
![](http://members.aol.com/_ht_a/rosenken/images/VEvalleysmall.jpg)
I haven't changed min yet, but it looks like the one the parts store gave me was wrong. Good thing i didn't get it tore down and find out. You know what sux? On the 95-99 you can get to that ***** without taking off the intake manifold. I still think you could mount that thing somwhere else and it would work fine.
ballerchris510
09-23-2015 08:46 PM
ballerchris510
09-11-2015 05:29 PM
