keypad
Old Dec 30, 2000 | 08:23 AM
primeevil711's Avatar
I need some help cuz for some reason my drivers side door keypad is failing and it's worked fine until we got a cold snap down here in FL I was wondering if the weather has something to do with it. The weird thing is that the passsenger side door works and if I use that to lock/unlock the doors,windows, or trunk then I am able to use the drivers side I don't have any clue what could be causing this but I do know that it's not good. Thanx in advance and if there is a previous thread on this I apologize, I'm at work and I don't have the time to do a search.
Old Dec 30, 2000 | 09:58 AM
Shugarhi's Avatar
loose wire somewhere? or fuse?
Old Dec 30, 2000 | 10:02 AM
Re: loose wire somewhere? or fuse?
Originally posted by Shugarhi
It could be but the keys themselves feel spongy and wouldn't a fuse disable the entire system or does each door have they're own fuse? I'm going to check it anyway cuz i need all the help I can get, so Thanx for your input.
Old Dec 30, 2000 | 10:07 AM
speednsound007's Avatar
whats a cold snap in FL?
60 degrees Mine works in MD at 20-40 degrees sometimes less so thats not going to be why...Probably a loose wire like he said.
PJ
Old Dec 30, 2000 | 10:31 AM
Re: whats a cold snap in FL?
PJ
no this winter it's been thirty degrees at night here.....reminds me of NY, but since the car has never been in such a cold climate I didn't know if that had an affect on the keypad itself, but since yours works then I have some wires and fuses to check.
Old Dec 30, 2000 | 10:37 AM
block's Avatar
I'm thinking it could be that the keypad is warn out. Mine fails in cold weather but if you press it enough it works. If you look behind the keypad (with door panel off) you can see that all it is is a couple screws to replace. I was planning on replacing mine because some of the #'s are warn off
Old Dec 30, 2000 | 11:00 AM
Thanx for the help and I don't want to get off subject but your site is tight good job.
Old Dec 31, 2000 | 07:21 AM
Tick Tock's Avatar
It's likely not a wire. I have posted this before but will again.
My keypad (driver's side) did the same thing and it took me forever to figure it out. It worked most of the time but when it got cold (but not always even then) it wouldn't work. Long diagnotic story - short:
One or more keys got a bit of water into them. When it got down below freeing, it turned to ice inside the button. This would make it so the button wouldn't work. In my case (and the most common case according to my dealer) the "start" button was the culprit.
The only reliable fix is to replace the whole keypad. Given the $$, I'd go to your local bone yard and pick one up.
Hope that helps!
Old Dec 31, 2000 | 07:33 AM
block's Avatar
by whole keypad you mean just the little pad and not the whole system right? just making sure
Old Dec 31, 2000 | 07:58 AM
Tick tock
I had a feeling that the pad itself. How much do you think it will cost to get a slightly used keypad, cuz I've been pressing it and it doesen't feel like it normally does, but THANNK YOU ALL FOR ALL THE HELP I REALLY APPRECIATE IT.
Old Dec 31, 2000 | 06:51 PM
Tick Tock's Avatar
Yes, just the keypad in the door. See the instructions in the FAQ's on how to dismantel the door (under the problem window regulator info). Frankly, if I were doing it again, I'd also replace my window regulator too since the door's apart already.
Anyway, yes, just the keypad on the door that doesn't work right.
markevans999
Sep 10, 2015 04:29 PM
videomano
Sep 8, 2015 03:28 PM
crazy4maxima
49
Jul 13, 2013 05:54 AM
marvelous93max
Jul 1, 2003 06:03 PM
rogman16
Feb 20, 2002 09:03 AM
