intake tubing
Old Dec 11, 2002 | 01:36 PM
AscendantMax's Avatar
intake tubing
i'm prolly gonna get flamed like crazy for this but how do you remove that intake tube that goes from the headlight to the main intake box? there's two screws that i can see that holds the tube onto the box. i did a search but didn't find anything helpful. or maybe someone can direct me to a link with answers? any help be appreciated. thanks.
Old Dec 11, 2002 | 01:42 PM
«§»Craig B«§»'s Avatar
Re: intake tubing
if it's the same piece I'm thinking of, then I think you may need to remove the headlight to get to it
to remove headlight: remove corner lense (one screw on top and then it pops outward if you pry at the front part - be careful not to break the tabs on the back end), then you'll see 2 screws with 10mm bolt heads on them that go into the side of the headlight
after removing those, you will also find 2 10mm nuts on the back side of the headlight housing on the side close to the grille
once those are out, you can work the headlight out (move it around to get the headlight alignment screws through their holes)
then you'll see 2 screws/bolts holding that plastic piece in
also, I just rememeber that the headlight bracket will be attached to the grille, just remove the clips on that side or remove the whole grille - 5 clips total
it sounds a lot harder than it really is - shouldn't take more than 20 minutes or so (5 minutes if you've done it before)
btw - this is for the square piece (maybe 3"x3" or so) that is directly behind the headlight and is about 3 or 4 inches long, the rest of the pieces between there and the stock intake can be removed more easily - couple screws here and there; I can't remember offhand where they are though because it's been about 3 years since I dealt with that
Old Dec 11, 2002 | 02:27 PM
D-sta's Avatar
Re: Re: intake tubing
I was able to remove that wihtout touching the headlight, it all matters on what tools you use, I have the snap-on open end wrenches that are ratches at the same time and thank god I bought those tools they come very useful and fit anywhere.
Old Dec 11, 2002 | 02:30 PM
KLoWnPR109's Avatar
Is he talking about the resonator? If so, that took me no time at all during my CAI installation
Old Dec 11, 2002 | 04:25 PM
which way is the easier route? take the headlight out or the open ended wrench? plus how much do those wrenches cost?
i want to remove that tube in hopes of getting better airflow
Old Dec 11, 2002 | 06:55 PM
D-sta's Avatar
Uhh I rather not take the headlight off because in the time it takes to do that with a little effort you can do it the other way. Actually once you get it turn you can turn the screws from the thread section and then you can just unbolt it with your hands, it worked for me this way in my car and my friends consider me to have big hands. Good luck
Old Dec 11, 2002 | 07:27 PM
yeah, if you can get it out that way, do it
I would check it out for you, but my intake and headlights are both not stock anymore so I can't really remember exactly where all the smaller pieces were exactly
your friends say you have big hands eh? just keep that between you and your friends
Old Dec 11, 2002 | 07:31 PM
well thanks everyone for their help . i'll see if i can get the thing removed with the help provided.
Old Dec 11, 2002 | 07:36 PM
Aaron92SE's Avatar
NWP Engineering.com
If you want better airflow, don't just remove this tube you're talking about. That won't do a single thing. If you are poor like me, then make your own intake. I believe this idea will work with the VG motors.
Here's what I did:
Buy a $25 APC 3" cone filter from a parts store.
Open up your stock intake box and take out that brass ring that has about 3 rivets. This will be your intake adapter plate. I got out my brass flange by ripping it out with pliers. That caused me to bend it all up and I flattened it back to normal with a hammer on concrete. Others might drill out the rivets with a very small drill bit.
Once you have the flange out and flattened back to normal, you have to bend the part that curves outward. Once you bend that as straight as possible, you can put your cone fitler over it and then tighten the clamp. When you bend this flange, it's going to look ugly and rippled, but you won't see it since the filter will cover it.
Other people have sawed off the curved part, which doesn't leave that much room for the cone filter to fit over.
There you have it... a $25 intake.
While you're at it, remove the intake resonator by following the instructions brought out at:
http://www.4dsc.com/articles/drivetr..._removal.shtml
Old Dec 12, 2002 | 04:11 PM
would it hurt if i leave the resonator in?
Old Dec 25, 2002 | 03:36 PM
MaximaBalla's Avatar
Are you sure your talking about the correct resonator? Because, the resonator is in the exhaust system further down the piping of the exhaust behind the cat.? I think the part that your trying to remove is called a snorkel? I just cut mine right out? And also, the resonator in the exhaust system in my car is now removed because it improves the sound and makes it sound a lot better!!
Old Dec 25, 2002 | 08:49 PM
yea but i don't want a insanely loud car. i just left my exhaust resonator in when i had my magnaflow installed. still sounds great. yes there's also a intake resonator...go to that link Aaron92SE provided.
Old Dec 26, 2002 | 02:31 AM
aw89maxSE's Avatar
You can be like me and take a hack saw and cut it out and then remove the little electronic black box but I wouldn't suggest it haha
Old Dec 26, 2002 | 07:23 AM
D-sta's Avatar
that would be taking the easy way out..
Old Dec 30, 2002 | 07:36 PM
Hey, I did it and I had no problems at all? Actually, I just got some really heavy duty cutters, cut it down the middle and just ripped the hell out of it until it came out!!
aw11power
Oct 10, 2021 04:57 AM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Sep 27, 2015 08:37 AM
