Please someone stop the hesitation
Old Dec 30, 2002 | 12:20 PM
Gjohnson's Avatar
Ok, I've cleaned the throttle body, I replaced the air filter and I changed the fuel filter. What else? I bought a new PCV valve but, could not change it for the life of me, any tips???
I don't know what else to check.
Here are my symptoms. When sitting a stoplight (Max in drive, sittinkg on the brake) the car will start hick uping or almost stalling. The rpms will start to fluctuate, but it will never stall. Then sometimes when I take off the car will lose power a kind of sputter. What can this be??? This usually only happens for the first 10 mins of driving. After the car is warmed up or if I really get on it, it will stop or lessen a great deal. I know I need to replace the spark plugs and I will as soon as I get paid, but is this caused by faulty spark plugs? Any help is appreciated.
Old Jan 2, 2003 | 02:31 PM
VisualEvolution's Avatar
Re: Please someone stop the hesitation
Try fuel injection cleaner maybe theres a problem there???
Old Jan 2, 2003 | 04:41 PM
Sudesh's Avatar
Re: Re: Please someone stop the hesitation
So i was reading in the factory manual because i know this is a pretty big problem for alot of people.
My biggest conclusion about this problem is that you guys should check out your throttle position sensor. Test it properly and replace if necessary.
Old Jan 2, 2003 | 05:46 PM
Gjohnson's Avatar
Where is the throttle position sensor? I'm willing to check about anything write now.
Oh, I already ran a fuel cleaner through the system and I don't see any imporvement. The fuel system cleaner I used was some cheap $2 STP stuff from Walmart though, do you think I should pick up some of the BGK44 ( is that what its called?) and try that.
Old Jan 2, 2003 | 07:22 PM
89sks's Avatar
Check and see if any of your battery clamps are loose, mine was. I had to give it a firm wiggle but it was loose. Also try a new cap and rotor, just dont get it at Advanced Auto. Check to make sure your plug wires arent touching. The last couple of checks are simple easy ones. Mine was doing similar things and a combo of these easy things seemed to help mine out a lot.
Good luck.
Old Jan 7, 2003 | 12:23 PM
qus's Avatar
qus
My car had your problem about 6 month ago, and it is getting worse, similar to (or worse than) what is described in the following post.
http://forums.maxima.org/showthread....hreadid=157896
He had Nissan dealer checked his car, and I think I will follow what the dealer suggested to change all the coils. I will have it fixed in next week and let you know the result.
Good luck.
Old Jan 7, 2003 | 12:29 PM
Gjohnson's Avatar
Ok, does anyone know where the throttle positon sensor is? I really think this might be my problem. And how do I check it?? Please respond.
Old Jan 7, 2003 | 01:21 PM
pezking4's Avatar
I'm willing to bet that someone is going to say not to do this.
Old Jan 7, 2003 | 02:31 PM
5spd92SE's Avatar
Dont do that.
Old Jan 7, 2003 | 05:11 PM
klymkow's Avatar
Also, check the timing.
Has anyone adjusted this for you prior to the hesitation problem?
This can cause your symptoms.
Quick check and easy fix.
Tim
Old Jan 7, 2003 | 05:21 PM
Soul Fly
6 new injector harnesses...MAYBE...my max did almost the same thing
Old Jan 7, 2003 | 06:01 PM
Gjohnson's Avatar
No, as far as I know the timming hasn't been touched. i just bought the car the 13th of December. I'm planning on get the spark plugs changed and hopefully that will cure all my ills. Pray for me.
Old Jan 7, 2003 | 10:25 PM
Matt93SE's Avatar
STFU n00b!
I'll be free this weekend if you want to bring the car by. pm or email me and we'll talk.
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
maxima297
Sep 30, 2015 03:32 PM
homewrecker
Sep 24, 2015 07:01 PM
JoshG
51
Sep 21, 2015 10:41 PM
