VE30 DE teardown
Old Jan 26, 2003 | 11:16 AM
varroom's Avatar
VE30 DE teardown
i want to take the front head off my 92 se to drill and tap a broken exaust manifold stud. However my haynes repair manual (72020)doesn't illustrate this engine. Ive gone as far as i dare without a manual. the chains on the side of this engine are a bit scary. the reason i started this was to eliminate the chirping bird sound that seemed to come from that area. i figured it was an exhaust leak. any ideas on the resourses i may need.
Old Jan 26, 2003 | 11:44 AM
Matt93SE's Avatar
STFU n00b!
a REAL factory service manual will do you wonders. look on ebay or call your local nissan dealer.
Old Jan 26, 2003 | 01:01 PM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by Matt93SE a REAL factory service manual will do you wonders. look on ebay or call your local nissan dealer.
Or, since you're dealing with the left bank you can remove the exhaust manifold, hoses, radiator and fans for easy access if you're (or someone else) skilled enough with a drill.
Old Jan 27, 2003 | 10:10 PM
Delvin's Avatar
I haven't done it, but if you have a VE you DON"T wanna go through all the work to remove the head just to change an exhaust stud.
Old Feb 6, 2003 | 01:15 PM
MrGone's Avatar
remove head = bad
dont do it unless you have to
remove headers
drill and tap
vs.
remove valve cover
remove partial timing chain cover
remove cams (or the sprockets on the end)
remove timing chain
remove upper intake
remove lower intake
remove headers
deal with oil and coolant
gasket set $$$
if your gonna take off the head, you might as well consider a full out rebuild, because the gasket prices simply cannot justify pulling the head to drill and tap. for the extra 5 mins of ease, it simply is not worth it.
MrGone
1993-VG30E-GXE
Oct 31, 2009 06:00 PM
1993-VG30E-GXE
Aug 23, 2009 11:23 AM
Nealoc187
Nov 10, 2007 11:45 PM
BigDogJonx
Sep 22, 2003 09:12 AM
ejj
Aug 15, 2003 05:19 AM
