temperature gauge problem.
Old Feb 8, 2003 | 10:16 AM
AscendantMax's Avatar
what can can cause the temperature gauge to shoot up to high really fast then hover there for about 2 seconds then fall back down to the normal range? this is the 3rd time this happened. can air bubbles in the cooling system cause this or maybe my thermostat is about to crap out on me? thanks for any info.
Old Feb 8, 2003 | 04:20 PM
phat's Avatar
it could be air in the system or the stat is just opening like u said. It could also be your temp. sensor
Old Feb 9, 2003 | 06:11 PM
Tall's Avatar
Temp gauge
Mine hasn't worked in 2 years, just kind of jumps around after my car gets up to temp. Car doesn't run very well now, but ran good for at least a year and a half after it went blatto. Just learning to ignore it.
Old Feb 9, 2003 | 06:20 PM
Re: Temp gauge
why risk the chance of overheating your engine without you knowing?
Old Feb 9, 2003 | 06:23 PM
Tall's Avatar
If I hit the dash is goes back to normal. Dealer said it would be $300 to fix it...I can deal with it.
Old Feb 10, 2003 | 04:46 AM
C-Dawg's Avatar
Find another dealer.
Old Feb 10, 2003 | 05:04 AM
darrick's Avatar
Dallas Nissan Enthusiast
well
I went through this a little while ago it 1s 1 of 3 things ,but if you can hit the dash and it gos back you know its the gauge (if it is go get one in the junk yard ) if not its one of the sensors near the water neck under your hood one is the sending unit to the gauge the other is the unit for the ECU replace them all if you want to make it EZ on yourself
Old Feb 10, 2003 | 11:25 AM
thanks for all the info!
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
doctorpullit
Oct 28, 2019 10:58 PM
D Mason
Jun 21, 2016 04:43 AM
Noela
Sep 26, 2015 08:22 AM
