Help! Somethings wrong with my Max
Old Feb 23, 2003 | 12:41 PM
adtp337's Avatar
I went to start my car this morning and it started up fine, but when I put the car into drive, the rpm's dropped way down and the car just died. I tried it again, and the same thing happened. I checked the transmission fluid and its fine. Anybody have any ideas? Anything would be helpful.
Old Feb 23, 2003 | 03:04 PM
Dark Lord Bunny's Avatar
Something like this happens to my best friends 97 240SX. We haven't found the cause of the prob, but try hitting the revs up for a while. About a half min or so of keeping it at about 4 or 5 and it should be running fine. When you do get the answer to this question let us all know.
Old Feb 23, 2003 | 03:15 PM
maximizeditalia's Avatar
this happened to my camaro twice once it was the pcv valve and another time there was a hole in one of the vacuum lines
Old Feb 23, 2003 | 08:01 PM
adtp337's Avatar
Where's the PCV valve located in a 92' Maxima SE?
Old Feb 24, 2003 | 08:33 AM
doomtoo's Avatar
That kind of thing happened to me when my tranny went bad. Was driving it, the whole car started shaking, I pulled over, and it dies. I tried starting it up in drive, and it shook and died, then I started it up in P, worked, N, worked, any gear, shake and die. I had no problems prior, mechanic said something got stuck in the radiator or something from the rain.. I dunno.
Old Feb 24, 2003 | 11:03 AM
Best bet is to get yourself a factory service manual. For the long haul of course.
Old Mar 23, 2003 | 11:50 AM
phreeezer's Avatar
Re: Help! Somethings wrong with my Max
I have a 92' Max GXE. I had the same problem, just about anyways. When I would start it up, and put it in drive or reverse, the engine would die. If the engine was hot though, I was able to drive it. It turned out to be the tranny.
SmokinMax02
18
Sep 11, 2015 12:25 AM
maximusrising
Sep 2, 2015 09:55 AM
Hailstatejig
Sep 2, 2015 06:52 AM
A32goldylocks
Sep 2, 2015 06:39 AM
maxocar
Aug 21, 2015 12:57 AM
