CAI Install Help
Old Jan 20, 2001 | 09:39 AM
jdholman's Avatar
I just bought a CAI from Cattman. It comes with a few pieces of paper the manufacturer (Place Racing) refers to as an "Installation Guide" if you can call it that. In a word...It stinks!
Does anyone have installation notes that they used in installing their CAI? Or possibly a better description of the process?
I have my battery and battery tray out, and the relay and fuse box pulled back.
Any help would be appreciated.
Regards,
Jim
Old Jan 20, 2001 | 10:54 AM
nubiannupe's Avatar
OG Maxima.org Member
I'm not sure, but isn't there something about that in the FAQ section? If not, you might wanna check out Kaleb's website or Craig Brace's website. Both have a wealth of info about almost everything. Best I can do, Jim.
Old Jan 20, 2001 | 11:33 AM
JonnyMax's Avatar
well assuming ou have dsiconnected all the stock airbox stuff...
You just need to lay the template sheet on the fenderwell, tape it down as indicated and start sawing away.
On my Install I actually eneded up cutting a little bit larger of a hole to prevent the tube from rubbing the edge.
I have a couple pics in my link in the sig, but you cant see much from them.
Old Jan 20, 2001 | 01:49 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Maximadriver.com, check around on there!! n/m
Old Jan 21, 2001 | 02:36 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
what do you need help with specifically?
im assuming everything is out...you mentioned battery tray and fuse box...so that leaves the stock airbox and tubing...ill just assume its out...
your next step is to cut the whole...just look at the template carefully...there should be a screw size circle...that matches up with one of the battery tray holes and this should give you an idea of where to cut the hole...
get the hole cut and install the new tubing etc...any more questions...just ask...please be a lil more specific so we can help you out more...
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
2kmaximel
Sep 16, 2015 03:19 PM
A32goldylocks
Sep 16, 2015 01:33 PM
Johnny9595
Sep 3, 2015 05:18 AM
