91 SE Third brake light out
My third brake light (the one built into the spoiler) does not light up. I pulled the bulbs out of the brake light housing and checked for voltage with the brake pedal depressed...nothing.
I have checked all the fuses and they are all fine.
The other brake lights work fine.
Happens that the light inside the trunk that lights up when the trunk is open also doesn't get voltage...is is related somehow?
Any ideas?
Thanks in advance for any help.
fourDSC
Any ideas?
fourDSC
myt 3rd light doesn't work either, even after i replaced the bulbs...some other members on here have the same problem...if you do a quick search, someone had a solution to the problem...depends on if you want to do it or not though......should the brake light have voltage reading if the pedal is not pressed???
MaxLife17
06-27-2019 01:37 PM
Maxima30
09-07-2015 06:13 PM
