Camshaft oil seal
Old May 20, 2003 | 08:21 PM
cdunn's Avatar
Camshaft oil seal
Is there a special technique to removing the oil seal? I can't seem to get it out. I've tried using a screwdriver but I can't get any leverage.
Old May 20, 2003 | 08:40 PM
todamax's Avatar
The FSM says use suitable tool.
Old May 20, 2003 | 09:05 PM
«§»Craig B«§»'s Avatar
I just used a flathead screwdriver to pry it out
just be careful to make sure you're prying on the oil seal only and not scratching the metal sides around the crankshaft
Old May 20, 2003 | 09:34 PM
keener's Avatar
Re: Camshaft oil seal
Make sure you pry from all sides and then the seal will eventually come loose. I used a knife to remove mine, along with a lot of patience. AGAIN, make sure you do not scratch the metal housing or the seal will leak upon reinstallation.
Old May 21, 2003 | 07:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
use a pick/hook to snag it and pull it out.
Old May 21, 2003 | 02:10 PM
cdunn's Avatar
I finally got it out. I used a small screwdriver to pry it out. I just needed to be more patient. Thanks for you help.
Old Sep 29, 2003 | 03:32 PM
doodoodoo's Avatar
I want to clarify the way to remove the seals after I did last weekends.
At the beginning, when I tried to pry the seal from the outside edge, I found it didn't move at all. After I studied the seal I ordered from nissan dealer, I INSERT a small screw driver into the inside edge easily and pryed the seal out without sweat. Because the center of the seal is metal, it is very unlikely to damage the surfaces.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
mpbclutch33
Dec 26, 2015 11:11 AM
