Trans fluid change advice. . .
Hey all,
I've been thinking of changing the trans fluid in my '92 Maxima (170 km.) I have a bit of a lazy shift from first to second.
I've read two opinions:
1) If I drain the fluid, I can expect the transmission to fail sooner because all of the particles that are holding it togeher are gone,
2) The other opinion says to change it to extend the transmission life.
Any opinions or experience? If I do dump the fluid, should I spend the extra money on perfromance fluid? (are they worth it?)
Thanks for the help!
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Re: Trans fluid change advice. . .
I change mine every 30,000 and have yet to have a problem with failure. To put things in perspective my car just turned 223,000 miles. As far as gear lubes go, I have no experience with performance lubes. I have always used valvoline 80w-90. I hope this helps.
Originally posted by DanNY
keener i'm going to say that he's referring to an auto tranny..not gear oil (5spd).
chris look at it this way..if you changed it and it fails..the tranny was on it's last leg anyway.
I think your mistaken.
You mean if you flush the trans you risk hurting the trans by getting rid of home helpful deposits. If you just do a simple drain and fill then it'll be cool because all you will be doing is basically letting it run out without any pressure.
I'm talking about draining it completely (removing the trans. cooler hose while the engine is running, as discussed in a previous post), then refillng it. If you only drain it, you only spill about 4 or 5 litres while there is probably twice that still in the system. But the "deposits" are the main reason for this post. Can anyone elaborate?
Thanks.
Thanks.
This is a very risky procedure. You run the chance of running the pump dry. Since it is so easy to drain the fluid (I don't even have to put the car on ramps) why not just change it 2 or 3 times. You'll be sure to get most the fluid out of the torque converter. Though a little costly in fluid, it's cheap insurance in light of potential problems. These trans seem to be the week link on the car. Max.org UK has some interesting write ups on the weeknesses of the trans. Might want to take a peek FYI
03-12-2020 12:06 AM
bryants95max
10-02-2015 12:52 PM
ag90fox
09-09-2015 12:22 PM
