Axle keeps slipping out when I drive.
I'm starting a new thread now that I know what the problem is.
After replacing my bearings and assembling everything together my drivers side axle will not lock into the transmission, I can easily push and pull it out by hand unlike the passenger side. So is it the snap ring? Or the groove that holds the snap ring in place with in the transmission? Or maybe I'm just assembling the components that attaches to the knuckle improperly... Thanks in advance for any help...
I'll go through the FAQ for more research.
Is the snap ring actually on the axle?
is the axle completely seated inside the tranny?
how are your suspension bushings? if they're REALLY worn, the control arm coupld pul away from the tranny enough to cause problems, but I highly doubt that's the case.
The snap ring is on the axle loosely but securely, it couldnt come off on its own. When I intsalled the components I made sure the transaxle went in all the way i couldnt push it in anymore. As far as the bushings I'm not sure but I'll check tomorrow. I havent had any prior problems with the axle until I removed the knuckle and installed the new bearing.
I got a question for you
If you're sure you did everything correct and all parts seem to be in order, did you make sure the axle you took out was the same length/size as the new one? Maybe your new axle couple cm too short. Is it possible, yes it is. During the rebuild process parts could have been mixed up or miss labled, we are human Of course I'm referring to the company how had rebuild "that" axle
are you SURE that ring is seated in the tranny?if it's a loose fit, then it may not actually be getting into the tranny where it's supposed to because it feels like it's bottomed out already.
when you put the axle in, crawl under the car and look at the space between the inner CV joint and the side of the tranny. there should be very little room. like 1/4-1/2". if there's more room, then take a rubber mallet and whack on the end of the axle until it pops in. the snap ring will stop it about 3/4" or so out of the tranny, then click in at 1/4- 1/2".
Originally posted by nubiannupe
That sounds like the snap ring. When I got my new axles, I had that problem and it ended up being the snap rings were not in as secure as they should be.
BTW count me as memeber #4 of your 3rd gen charcoal gray maxima club. I wish I had some pictures.
Re: I got a question for you
Because there are like 9 different axles for the 3rd gen its possible someone messed up the rebuild.
Re: Re: I got a question for you
Originally posted by LegitMafiaBoss If the axle is not the correct length then how come it didnt slip out previously? I had my struts and springs replaced after my axle replacment and it didnt slip, but I had a shop do it so maybe they did it correctly. At one point I did think that the axle is too short. But when I remove all the components and intall the axle into place I can feel the end of the transaxle shaft hitting the "inside wall" of the tranny cylinder. Maybe the axle is too long thats why the snap ring isnt engaging with the snap ring groove? Because there are like 9 different axles for the 3rd gen its possible someone messed up the rebuild.
Re: Axle keeps slipping out when I drive.
I had same problem with my NX - you'll need to replace the snap ring. Get one at any auto-parts store or the shop you got the axle rebuilt / replaced. Your old ring too loose to lock into place - look at the groove on the axle and that's the size of the groove in the trans housing.
RealityCheck
10-02-2015 06:34 PM
The Wizard
24
10-01-2015 08:47 PM
