replacing Condenser
Old 06-03-2003, 06:25 PM
maximalover's Avatar
replacing Condenser
I am planning on replacing Condenser on my 93 Maxima..
As far as I know the steps
1. drain the coolant..
2. disconnect all hoses to radiator.
3. Remove Fans and then radiator..
4. ?
5. remove condenser..
6. put everything back
Now I see a slim frame running on top of radiator.. should I remove this..?
Also should I remove grille..?
Am I missing anything ? other wise I will be struck on saturday morning
Appreciate your input guys..
maximalover is offline
Old 06-03-2003, 08:13 PM
rcy
rcy's Avatar
Re: replacing Condenser
4. ?
Evacuate your A/C system of freon (or R134a - I think in '93 Nissan converted from R12 to R134a). Don't just bleed it off, it should be recovered to be reused or recycled. Of course, when you recharge the system, you'll need to create a vacuum in the system to remove any air/moisture that will undoubtedly get in the system when you remove the condenser...
rcy is offline
Old 06-04-2003, 05:22 PM
drstillpatient's Avatar
4. ?
I would be very interested in how this turns out for you...i have to replace my condenser as well....its had this whole at the bottom so i guess all the gas is already out ...its had this whole for the past 6 months now and i was waiting for the summer to change it...anything i should keep in mind while replacing and recharging the system?
drstillpatient is offline
captchaos
03-15-2016 12:18 PM
PH98I30
26
10-12-2015 05:01 AM
dvcamp
09-18-2015 10:17 AM
dcam0326
09-08-2015 11:02 PM
Maxima30
09-07-2015 06:13 PM
Quick Reply: replacing Condenser
