Silly strut / spring mistake, does it matter?
Old 06-11-2003, 11:14 PM
Jesse93GXE's Avatar
Okay, so I started my first strut replacement today, needed it bad after 130k miles on original struts... had a long fight with a seized bolt which I eventually won.
Anyway, after putting my stock spring on the new strut assembly (KYB GR2), I realized I had put the Front Left (FL) spring on the Front Right (FR) strut assembly. Does it matter? It seemed to fit okay. Are the springs side-specific? The springs are the stock OEM springs.
If it doesn't matter, I'd rather leave the spring on the FR strut assembly and move on.
Also, what does that thin papery/rubbery triangle do that goes under the 3 strut tower bolts? It's pink and just seems to go under each bolt.. but it's so thin I can't imagine it's doing anything useful. Mine was pretty crappy and a bit torn.. should I just throw it out?
Thanks,
Jesse93GXE is offline
Old 06-11-2003, 11:16 PM
KLoWnPR109's Avatar
I think you are OK, as long as you didn't put the rears on the fronts
KLoWnPR109 is offline
Old 06-11-2003, 11:28 PM
ghostmax's Avatar
Re: Silly strut / spring mistake, does it matter?
Thanks,
i think that's a noise dampener. you might want to keep it or replace it with a new one. probably don't cost that much. i think my passenger one is torn.
ghostmax is offline
doctorpullit
12-12-2015 09:39 AM
MaxLvr21
10-17-2015 12:11 PM
JakeOfAllTrades
10-05-2015 10:40 AM
JakeOfAllTrades
09-30-2015 03:16 PM
followthadollar
09-27-2015 01:06 PM
Quick Reply: Silly strut / spring mistake, does it matter?
