will injectors of a different year work
#42
same here i hate changing these injectors either they leak ,stick or the just crap out all together. i prefered the later model fuelrails and pig tail plugs vs older clip style plugs personal preference though! The safc controller should lean these injectors out enuff to become efficient. Im not thinking jwt or nistune ecu's. I dont see spending that kind of money anymore since im not looking for any performance gain's just want to keep my car tip-top shape.
Just a thougt has anyone put 4th gen injectors in the ve-s without a cel?
Also GREENY when you put the 4th gen injector in did u have a cel on the gxe?
maybe if i weren't dead-*** broke i would do that. better thing to do is to use nistune and just modify the injector size and i think it takes care of the rest. even so the SAFC would have to drop pressure to just 20psi to compensate, which probably isn't high enough to properly atomize the fuel, resulting in crappy power and crappy MPG.
#43
o i changed my oil a few hours ago and after one cold startup, the lifter clack did not occur. i will see what happens tomorrow when i start it cold.
however i am consuming oil. not very much came out when i drained it, and before i changed it i checked the level warm and it wasn't even reading on the dipstick. i'm going to do a compression test as soon as i can to see what i can find out there. yes, shame on me for not checking my oil level more often but after 35k miles of NO oil consumption whatsoever i guess i just took it for granted that my engine didn't leak/burn oil.
#44
change those injectors out ASAP or you will destroy your engine quite literally.
#45
yea that makes sense. tested compression today. cyl1-5 are 177+/-2psi, and cyl6 is randomly 191psi. FSM spec is 173psi (with a minimum acceptable spec ov 128psi). hopefully the new oil and the still-good compression will buy me enough time to get it straightened out.
#46
oic. does it just like, make the MAF signal reduced so the engine thinks less air, thus, less fuel?
#47
i do have a question about the compression for anybody who knows the answer... all of them did get to 173psi or higher, but alot of them took their damn sweet time getting there. like, cylinder 3 hit 125 the first time. i released pressure, cranked again. 160. release and crank again. 170. release and crank again. 177. same for cylinder 5, and i think either 2 or 4 did the same thing. 1 was instantly perfect, and i think 6 was as well. does that *actually* mean my compression is bad even tho it still hit spec after a few iterations of testing?
Finkle
09-27-2015 09:53 PM
Ray229Harris
09-16-2015 08:16 PM
jerrod99_se-l
08-27-2015 08:27 PM
