the boosted max gets stuck in 2nd again!
after tearing into my tranny for the the 3th time to disengage 2nd gear, I must once again open it up and deal with the evil spring that has caused me so much fustration and pain. ( for those of you that dont know or remember, I had rebuit my tranny and forgot to put in one of the springs for the shift rod, so every know and then i would put my car in rev, and the tranny would get stuck in 2nd. I lost the spring and ordered one from the dealership, when i recevied the spring, it was 2.5 inche longer than the original, I had to cut it to fit, but i ended up cutting it to short, so after putting everything together and putting it into rev. it got stuck again. I tore the tranny apart again put in a longer spring and everything work great for about 3 weeks)
today I was driving down the street and realized i forgot something at the house, went to do a quick u-turn couldnt make the turn, slammed it in rev, and got stuck in 2nd. had already swapped over to a t3/t4 and I hit boost at 2200rpm so it was and interesting drive home hit full boost and being stuck in 2nd.
Sorry just need to vent, i was looking foward to making the northshore maxima meet on sunday, but now i have to fix the car on sunday instead .
Originally Posted by Matt93SE
that sucks...
are you sure it's the spring causing it? are all other clearances correct? shift forks in good shape?
Originally Posted by SeaMAX
4sign..any thoughts on fabricating a kit yet for us less fortunate turbo-less 3rg genners?
I really dont have the time and the resources to fabricate a kit at the moment, but im willing to help anybody who wants it
i cant beleive the spring is suppose to be cut to lenghth or did the dealer give you the wrone one. when mine got stuck in second we just strechted the original spring out and it has been fine for about 8 months so im not sure
hey i could use some help. what do i need to get my ve boosted !! Well i know what i need obviously but what parts and from what manufacturer did you use ? B4 i do this i have to replace the vtc's and the knock sensor.
Then don't waste your time trying to boost the max or even bother getting parts for it. by the time you're done fixing the VTCs and knock sensor, you'll either know what you need, or you'll be ready to sell the car.
HOw much for a set up??? I am willing to invest in the turbo. Let me know what i need. I also have a friend is is willing to do it, but needs to find someone who knows what they are doing and that they are gonna take care of the max.
just a thought....you might be able to release 2nd without taking the tranny out. If you remove the bolt, spring and ball bearing (and oil) you could probably get a small screwdriver up there to pop it out of gear. Get the wheels off the ground so there is no load on the gear. It shouldn't take much force.
pktaske
05-06-2016 07:49 AM
pears
09-18-2015 05:25 AM
pktaske
09-04-2015 08:40 AM
