help my abs ligth keeps coming back
Old Oct 30, 2003 | 08:34 AM
espimax's Avatar
my abs light keeps coming back even the deler fix it but it comes back, i allready replase two sensors but i don`t want to keep buying the other two it will go off but i will hit a pothole on the road, and it will come back and also my stoping distance worse now they don`t stop as good no more, any one with same problem or advice please help.
Old Oct 30, 2003 | 08:48 AM
tmuscedere's Avatar
On the computer under the rear dash, how many times does the light blink? That will tell you where the problem is.
Old Oct 30, 2003 | 09:24 AM
Jack.'s Avatar
Click Here Good info, but if you already know it all just skip down to the bottom which has the table of what the warning light's code is.
Old Oct 30, 2003 | 09:55 AM
internetautomar's Avatar
mod or sell?
Your harness is bad! not the sensor. the dealer didn't do his homework.
Based on what you are saying there is a bad wire/connection in the wiring. It'll be a pain to hunt down but probably cheaper to fix.
Old Oct 30, 2003 | 11:47 AM
espimax's Avatar
were is the abs computer located is that the one on the rear deck, begain the rear seat between the rear speaker? thanks for the responce.
Old Oct 30, 2003 | 11:50 AM
tmuscedere's Avatar
When you look in the trunk its under the rear deck on the right hand side. There is a little LED on the bottom, count the number of lights that it flashes. After you have the ABS light on, leave the car running and count the number of flashes.
Old Oct 30, 2003 | 08:30 PM
espimax's Avatar
I Know It Under All The Speaker And In Top Of The Subs And Is All Sealed With Acustic Insolation, It Is Never Easy For Me, Thank You I Was Afraid Of The Answer. There It Goes My Weekend.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
stromm
Aug 27, 2015 04:13 PM
Lowered_a33
Aug 24, 2015 04:35 AM
