brake light
Old Dec 5, 2003 | 04:05 PM
mjax10's Avatar
brake light
got a problem with my tail light. My tail light one of the light socket melted one of the leads so I replaced it with universal socket with no problem but the tail light stays lit until i take out the fuse. What is causing this? I dont want to get any tickets for brake lights not working. HELP
Old Dec 5, 2003 | 04:12 PM
Matt93SE's Avatar
STFU n00b!
sounds like you fried something or crossed some wires while doing the repair.
not really much we can do to help without being able to work on the car ourselves.
Old Dec 5, 2003 | 08:16 PM
94MAXGXE
Even with the car turned off? = >take out the fuse<
What tail light stays on? Brake light?, running light? backup light?
Old Dec 6, 2003 | 01:54 PM
mjax10's Avatar
brake light
The running lights would stay on all the time untill I would remove tailight fuse. but now lights go off when I turn lights off but I still don't have brake lights. One more observation I have an automatic and I use to hear click noise whenever I would press brake pedal to move shifter from park to rev or to drive. I don't hear click noise. does stop switch have anything to do with that?? I have no blown fuses and I replaced all brake lights ie 1157.
Old Dec 6, 2003 | 01:56 PM
mjax10's Avatar
running lights/brake lights would be on at the same time.
Old Dec 6, 2003 | 06:32 PM
internetautomar's Avatar
mod or sell?
Check your stoplight switch it may be sticking
But I think it is probably the wiring you did
Old Dec 6, 2003 | 08:00 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
yea sounds like wiring to me ! or something else melted along the line and is shorting out.. check all the wiring. i know its a pain but you may find something and even if you dont you know that thats not the problem.
Old Dec 6, 2003 | 09:53 PM
DMad8724's Avatar
umm im pretty sure your clicking noise is your shift lock mechanism...nothing to do with your lights im pretty sure...if you dont press the brake down...you cant shift...when you press the brake down it clicks, then you can shift...called shift lock
Old Dec 8, 2003 | 12:54 AM
mjax10's Avatar
anyone know what the stop switch actally does?and do 3rd gen maxima have 2 stop switches.
Old Dec 8, 2003 | 01:06 AM
«§»Craig B«§»'s Avatar
stop switch just makes contact when the brake pedal is pressed to send power to another unit
maxima has 2 switches - one gives power to brake lights, other goes to cruise control cancel
Old Dec 8, 2003 | 07:10 AM
mod or sell?
The switch on the right (looking at it) is the brake switch.
or at least it appears to be. Works for my remote start to kill it like it's supposed to
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
