engine missing
Old Dec 16, 2003 | 06:33 AM
suzook's Avatar
engine missing
it feels like my engine isnt running on all cylinders.i replaced the cap and wires.i know i am getting good spark.could it be a bad injector?i know someone metioned do a ohm check.anyone have instructions on how to do this?what ohms should they be at?any other suggestions to what the problem might be would be appreciated.btw i have a 93 gxe.thanks
Old Dec 16, 2003 | 06:36 AM
nubiannupe's Avatar
OG Maxima.org Member
Off the top of my head, ohms for the injectors SHOULD be around the 10-12 ohm range. Just take a DMM (that's digital multimeter, for those NOT in the know), set it for "ohm", put both leads on the "+" and "-" pin on the injector itself.
Old Dec 16, 2003 | 07:13 AM
subs1000w's Avatar
sounds like an injector
to check the front injectros on the vg theres a plug on the right side below the egr valve it has 4 pins theres one for ground and the other 3 are the 3 injectors so you have to keep you black meter leed on the ground and swith the red to the other 3 the backs you just unplug each one and check them induvidually like stated above
and i also believe its 10 to 14 ohms but if one reads nothing its bad
Old Dec 16, 2003 | 11:55 AM
internetautomar's Avatar
mod or sell?
Oh c'mon guys VG never have bad injectors
j/k
conansriver
Nov 18, 2015 02:46 PM
dcam0326
Sep 18, 2015 04:52 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
A32goldylocks
Sep 2, 2015 06:39 AM
