wierd idle...
Old Feb 26, 2004 | 07:42 PM
liquidsnow's Avatar
wierd idle...
OK maybe someone here knows about wtf is going on in my car.. the egnine idles normal.. then it starts jumping from 1000 to 2300 rpms...
and wont stop doing this unless your actually moving (only does it in park and nuetral) when your driving it runs great power and everything..
but when I turn off the car it smells like gas... flooded in the engine.. like if it was carbed.. maybe someone could give me an idea of whats going on A mechanic told me I need a new timing belt... tune up.. and a o2 sensor.. but I watched him mess with the idle air control valve.. *lost* any tips would be great thanks!
Old Feb 26, 2004 | 07:47 PM
liquidsnow's Avatar
eh.. sorry it's a 93 gxe sohc.. 120,000 miles automatic.. stock.. everything... I believe (bought this car from its first owner)
Old Feb 27, 2004 | 06:06 AM
internetautomar's Avatar
mod or sell?
You ARE due for a timing belt based on mileage.
as well as everything else he mentioned.
But chances are those are not related to your erratic idling.
Startt with the maintenance items then see if the problem either changes or goes away.
Old Feb 27, 2004 | 09:57 AM
liquidsnow's Avatar
:\ hmmm I was looking at the hose that goes to the iacv and it has electrical tape wraped on it and no clamp... maybe that could be the problem
Old Feb 28, 2004 | 04:55 PM
liquidsnow's Avatar
:| no one else got any.. thoughts to share on my problem... doing the t-belt didnt change anything.. mechnic said the ignition wires, plugs.. are still fine..
Old Feb 28, 2004 | 05:31 PM
evilvamp7's Avatar
i had the same pro and puthe car on computer and it working fine it's the meter that's wrong change it you will be fine
Old Feb 28, 2004 | 06:15 PM
liquidsnow's Avatar
it's not the meter though.. I can actually see/hear the engine reving up and down.. unless the a/c is on and working.. or the car is in drive/reverse
Old Feb 29, 2004 | 04:44 PM
liquidsnow's Avatar
I replaced the vac line that goes to the iacv... seems to have cured some of the problem.. anyone know how to adjust that thing.. seems like it's sucking to much air... cause when I squeeze the line it idles normal
Old Feb 29, 2004 | 07:03 PM
Scope's Avatar
Im izz sexay
can an engine have too much air? You should try to adjust your idling throttle.
Old Mar 1, 2004 | 01:54 PM
liquidsnow's Avatar
I dont know how...
Old Mar 2, 2004 | 01:50 PM
liquidsnow's Avatar
:\ guess nobody here does either.. heh.. time to take a trip to the dealer then
Old Mar 3, 2004 | 08:20 AM
liquidsnow's Avatar
the adjust screw.. has something like an o-ring on it.. anyone know where I can get this I cant find it in any auto parts.. it's leaking so.. Im guessing thats why I cant adjust it
Lakersallday24
Jun 16, 2019 01:35 AM
MaDMaX024
Nov 3, 2001 11:02 AM
KITT
Nov 27, 2000 01:26 PM
KITT
Nov 26, 2000 07:02 AM
