Help...
Old Mar 15, 2001 | 08:44 AM
crsmax's Avatar
Lately when starting the car on some cold mornings, I get a ticking sound (sounds like its coming from the cams) until the engine warms up? Any ideas?
Old Mar 15, 2001 | 09:02 AM
ghostmax's Avatar
I'm no pro, but seeing as how no one's offering advice....
1) Could be the exhaust manifold studs that have broken and are just rattling. To fix, you need to drill them out and replace. The dealers will charge a lot for this since the labor is high I guess. A very common problem on the VG's I think. I have it on my car, but I just let it rattle
2) Possibly the lifters, but most likely the first.
Good luck.
Peter
Old Mar 15, 2001 | 09:30 AM
crsmax's Avatar
Good luck.
Peter
Thanks for the response bro... although I think that the exhaust stud problem was more common on the VE's, but anything is possible...
Old Mar 15, 2001 | 12:13 PM
singhg83
im not a pro either, but i hope its not the vtc. Im not really familier with the VE's engine, but its comman thing with alot of the Ve's
Old Mar 15, 2001 | 12:17 PM
Jeff92se's Avatar
I'm needing a caw
Since we don't know what engine you have.... the ticking could be alot of things.
1) Lifters
2) Chain tensioner (VE)
3) VTC (VE)
4) Exhanust manifold studs(VG and VE)Common on both.
5) About 2-3 other various things
Old Mar 15, 2001 | 03:12 PM
crsmax's Avatar
Engine Type
1) Lifters
3) VTC (VE)
I know its a VG... I'm the second owner, and unless someone stuck a nice VE in there for me, then I have to admit I'm stuck with the VG...
Old Mar 15, 2001 | 03:13 PM
crsmax's Avatar
Interested in Other Ideas for VG
1) Lifters
3) VTC (VE)
Old Mar 15, 2001 | 03:14 PM
Jeff92se's Avatar
I'm needing a caw
Re: Engine Type
Then I think we can narrow it down to sticky lifters or an exhaust manifold stud breakage. Or maybe a overly loud injector?
Old Mar 15, 2001 | 03:18 PM
crsmax's Avatar
1) Lifters
3) VTC (VE)
Old Mar 15, 2001 | 03:52 PM
HoJo's Avatar
What kind of oil filter do you use? In my experience with Fram filters did this, they don't have an anti drain valve. All the oil drains out of the top of the engine and it take a bit to build up oil pressure to be able to pump oil back up. Thats why it is more noticible on cold mornings, oil is cold harder to pump.
Old Mar 16, 2001 | 08:56 AM
bigjay's Avatar
vtc
if this is just a startup thing and happens at no other time i would say vtc
Old Mar 16, 2001 | 09:05 AM
Jeff92se's Avatar
I'm needing a caw
Re: vtc
Ah that would be really hard problem to have consider he doesn't have any VTCs.
crsmax. That idea about the oil filter is a good idea. Make sure to use a Nissan one and see if that solves it.
Old Mar 16, 2001 | 10:32 AM
bigjay's Avatar
sorry thought he said there was a stud problem on his ve, i hope you can excuse my ignorance oh mighty one
Old Mar 16, 2001 | 10:43 AM
crsmax's Avatar
Oil Filter
You know what fellas, that might be it... I'm due to take the car in for an oil change this weekend anyway, I hope this solves the problem. I'll keep everyone posted. Thanks for the suggestions...
Would a low oil volume (really needing an oil change) cause the same kind of effect?
Old Mar 16, 2001 | 10:48 AM
Jeff92se's Avatar
I'm needing a caw
Re: Oil Filter
Yep, low oil might do it also. If your using 10w40, you might want to give a 5w30 a shot.
BigJay. Hey post some pics of those blinks in the mirror thingies. Those sound pretty badassed.
Old Mar 19, 2001 | 09:42 AM
crsmax's Avatar
Re: Re: Oil Filter
[QUOTE]Originally posted by Jeff92se
[B]Yep, low oil might do it also. If your using 10w40, you might want to give a 5w30 a shot.
Thanks to all that responded and helped to diagnose the problem. My baby was just thirsty and need a new filter and oil change... So far so good, no more ticking...
secoske
Dec 11, 2017 10:39 PM
maxxxed out
May 4, 2002 10:03 PM
MaxedOut2g
Apr 24, 2002 06:46 AM
samiam
Apr 15, 2002 07:50 AM
