VG Hybrid Intake Pics + Writeup
yes you need to find a way to cover the nipple hole. wat i did wit the niple hole wasnt really sealing it. i sawed off most of the nipple and left a little bit of the nipple there. i used a wrench and squeezed the hole together so that there was no air leak or anytthing. also if you plan on doing this, before you start up the car, make sure you get all the little shards of metal out.
Pitbull where did you get the Template from? Ive been looking around cant seem to find it.... And as for the bypass valves where does it get put in the cai. should it be located somewhere in the alluminum...meaning more cutting?
Originally Posted by aziphrale
What kind of maf adapter did you use?
the original poster used:
"I eventually purchased a MAF Adapter and Intake combo for a 93 Z32, from the same seller above on eBay ($20 or so shipped)
http://www.cattman.com/img/prod/dsc_...20g5%20cai.jpg
is this intake any good.... i heard that the styrofoam filters are ****... im wondering if i can put on a normal one, but the thing is that its supposed to fit the maxima witout any cutting...
http://www.cattman.com/prod_intake.html
If you look at the 90-93 accords intake there are two parts. The midpipe and the other pipe leading inside of the fender well. The midpipe is the pipe that ends at our stock location thus preventing any cutting to the fender well. The other pipe you'll have to cut the fender to get to the true CAI approach. WHy pay over 200 for something you can pay 60 for and get similar gains?
BTW that pic is not for the VG engine.
Originally Posted by jaguax
The coolant reservoir is on the left side of the VG unless you have ABS.
edit - Actually I think it should be on the left side regardless of whether you have ABS or not because I just saw a VG on ebay with ABS and the coolant res. is still on the left side.
I've been thinking of putting together a CAI out of an upper tube from WSP and a JWT pop-charger. That'd certainly be easy to make fit...but also very pricey :\
Originally Posted by amaxima
I bought a MAF Adapter separately, the one in the pic is junk. Don't buy any MAF Adapters you're unsure of. I eventually purchased a MAF Adapter and Intake combo for a 93 Z32, from the same seller above on eBay ($20 or so shipped)
Just drill out the 2 rivets holding it on. Have it trimmed down, $10-$15 at a local machine shop. And bolt it up to the MAF. It already has the nuts for the bolts. And a 3" air filter clamps on almost perfect (depending upon how good the shop is) The shop I took mine to did a great job.
Originally Posted by VG Ill ridah
Or get a dremel and do it yourself.
The last time I used a dremel it was on my friend's sub woofer box. He had just bought the new hand held attachment for his, and we decided to use it on the box. He was upgrading his terminals. Got a little carried away...
I'm stuck right now between a dremel... or a Plasma Cutter
I would get both, but I want to finish the stereo in my truck.
Originally Posted by xnyc
pretty much it. do you plan on doing the 2nd pipe or just the first one between the intake manifold and maf?
Mahmuth
Sep 17, 2015 11:45 AM
So much fun to cut stuff. Of course I have to try and hold back. Or I'd have a new style of pinstriping on my car. And my wife would be pissed
