Power doors and keyless entry
Old Apr 18, 2004 | 04:30 PM
unctarheels5's Avatar
I have a 93 maxima, and the power doors dont work. When i press the button for them to work, you can hear the switch down under the steering wheel making a noise, but i dont know what its doing. This is also making my keyless entry not work, since i put in the code and go for it to unlock it just makes the same sound and wont unlock. any ideas on how to fix it?
Old Apr 18, 2004 | 05:44 PM
«§»Craig B«§»'s Avatar
very common problem on 92-94s. The door lock timer needs to be resoldered. It's a grey plastic box just to the right of the steering column after you take off the lower dash piece. It actually has a sticker that says door lock timer and you'll hear it click when you press the lock/unlock button.
If you dont know how to solder, contact Matt93se (or myself) and he'll take care of it for a small fee
Old Apr 18, 2004 | 09:30 PM
MaximamixaM's Avatar
I think I read that you can try pressing that area of the dash and it might occasionally work when doing that-if so it definitely would be a bad DLT-not that pushing the dash is a fix
Old Apr 23, 2004 | 06:03 PM
Belac's Avatar
keyless entry
where can i get the remote for the keyless entry?
Old Apr 23, 2004 | 07:39 PM
no US 3rd gens came stock with remote keyless entry so there is no remote to get
you can install one yourself though if you have some wiring experience (check out the FAQs for more info)
Old Apr 23, 2004 | 08:16 PM
maximagxe90's Avatar
Hi,
my car has the some problem,
when i try to lock the doors in side by the button unlock/lock it doesn't work so i have to manually looks the doors in order to activate the security system so this problem is on all the gxe 89-91 and the 92-94,
Old Apr 24, 2004 | 05:09 AM
Originally Posted by maximagxe90
Hi,
awesome, but your car doesn't have a door lock timer so it's a different problem (maybe the main lock/window switch)
Old Apr 24, 2004 | 07:18 AM
Hi,
Craig B,
do you know what the setup for the keyless entry on the 90 gxe?
Old Apr 26, 2004 | 12:39 PM
mpdugg's Avatar
Lock Timer Box Write up
The tutorial is not perfect but it should help with the fix.
http://www.theduggans.us/cars/maxima...ckTimerBox.htm
Matthew
ajahearn
Sep 19, 2015 03:03 PM
flu2000
Sep 14, 2015 12:34 PM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
