VTCs again
I have just pulled the forward facing head off to find a badly burned exaust valve. I am taking the head to have the valve seat resurfaced and will replace the valve--no problem.
I have been hearing the rattling from my engine for about a year. While I had the engine apart I decided to investigate this as well. From what I read here I have decide that it is the VTC sprocket or sprockets. The question is does a bad VTC sprocket lock-up as in not shift, shift too easily, or not shift at the right time? I have only reached one of the sprockets and it will shift on the cam with moderate pressure. The sound or rattling I heard sounded like it was coming from the rear head which I have not and would rather not remove. If the front VTC sprocket is ok and the rear one is bad I will swap them so that the bad one is on the front and easier to remove. Then I can deal with it later after I harvest my money tree. I have heard here and on maxfaq that there is a bulliten from nissan about this, do any of you have it? I think that would probably answer all of the above questions.
I understand that nissan had this common problem fixed in the 94 model. Can the 94 VTC sprockets be used in a 92 motor?
Finally, I hear alot about CAI or Pop chargers and Y-pipes but nothing about throttle bodies and headers. Is this because the stock components are good enough or are these not available?
Thank you
Thank you
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
JonnyMax
Jan 25, 2001 08:58 AM
