CAI How To?
Old Jul 11, 2004 | 01:56 PM
Phil93MaxSE's Avatar
CAI How To?
I went ahead and picked up a CAI off of ebay and tried to put it into my car (with no instructions since there was none given), but failed. I need someone to either take a picture of a CAI hook up under the hood of thier car or someone to give me a parts list of what i should have in the kit, just so as i can make sure that the guy gave me all the parts i need cuz i'm not sure if i'm missing anything. I've got a 93 Maxima SE DOHC
Old Jul 11, 2004 | 02:45 PM
Michael's Avatar
Back in a 3rd Gen.
http://home.comcast.net/~Michael-H/cai/caitemplate.pdf
That is the template you will need to cut the hole in the fenderwell.
Compliments of Portdave and CraigB. I never got around to making one but told Dave where to cut and he made the template from there.
look on my site to see it installed.
Good luck...
Old Jul 11, 2004 | 05:08 PM
MrGone's Avatar
1. Put tubes/filter/othercrap in car
2. Drive to Jeffys house
3. Build CAI
4.
5. Give Jeffy spare tubing so he can make one too
6. ????
7. Profit!!!
I've seen that posted a few times this week lol. I think on Matt's the hole was more of an oval (went more towards that existing hole for that wierd resonator thing a ma bob).
Old Jul 12, 2004 | 08:10 AM
Jeff92se's Avatar
I'm needing a caw
I got your pm Phil. Which ebay cai did you buy? Why doesn't it fit? I don't really have a good way to cut a hole in your fenderwell for those ebay CAIs. I suppose you can hack a hole with a 4" grinder with a cut off wheel. I could use a worn out wheel that's like 2.5" now. hehe.
Old Jul 12, 2004 | 08:11 AM
Jeff92se's Avatar
I'm needing a caw
What are you talking about?
3. Build CAI
4.
6. ????
7. Profit!!!
Old Jul 12, 2004 | 11:06 AM
MrGone's Avatar
I thought Matt cut his hole out more like this:
Old Jul 12, 2004 | 11:53 AM
i purchased one from liveonspeed; it claimed that it fit a 92-94 maxima SE DOHC, i tried putting the thing on and the tubing i was given doesn't fit at, on top of that there's no real support to the rest of the piping leading to the air filter, so if i install it, it looks like its just gonna hang there.......it's a pretty poor setup if you ask me, i might just junk the part and go with an injen or warpspeed that i'll know for sure will fit.
Old Jul 12, 2004 | 12:03 PM
taking a look at aswm66's CAI, it looks a lot like the one i got. The one question i have to ask is that the piping peice that connects to the intake manifold, was the piping the same diameter as the intake manifold hole, or was it much larger?
Jeff92se's Avatar
I'm needing a caw
http://forums.maxima.org/showthread....71#post3085371
I could make you just the piece you want. But it still won't really have support. I use a support piece I got with the JWT pop charger to support maf. I believe alot of guys just let the system hang as the couplers keep it lifted. It would be fairly easy to make a support bracket.
Old Jul 12, 2004 | 12:15 PM
James92SE's Avatar
2 VE's are better than one!
They're all like that. The ebay one is exactly the same as the WSP and actually seems to be better designed than my WSP cai (with that little flare tip to position the filter better in the fender)
Injen doesnt make one for us btw
Old Jul 12, 2004 | 12:39 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i have one from live on speed also. and i have the 93 ve30de 5speed. it fits fine. however the rubber part that connects to the throttle body was a bit big, just crank down the hose clamp....
Old Jul 12, 2004 | 01:00 PM
the rubber part and the piping is big over the throttle body for mine, and i'm afraid overtightening the part to compensate will cause an air leak
Second thing i wanted to ask was do you take the intake off when it rains since the filter will sit underneath the fenderwell if i have to cut a new hole in the fenderwell in order for it to fit
Old Jul 12, 2004 | 01:19 PM
MrGone's Avatar
oh, I didn't realize Phil was local, sweet!
Might want to take Jeff up on his offer. I dont have anything supporting mine but the hose couplers but it really doesn't move. As for the rain, I dont really even think about it. Saturday I did go though a rather big puddle in the road, afterward I was a little worried about the altenator, but aside from that, bah. The inner fender is pretty well inclosed.
Old Jul 12, 2004 | 01:36 PM
yea alright thanks Mr. Gone, i won't need to worry about that part then cuz i was reading injen's disclaimer saying that thier's needed to be taken off during the rain or else water can get into the engine and cause problems. i was contemplating just slipping on the piping over the lip on the throttle body even though its large, but if i put that peice in, i've got some loose hosing that doesn't fit......this is so confusing!!!!!!!!!!!!!!!
Old Jul 12, 2004 | 01:45 PM
Michael's Avatar
Back in a 3rd Gen.
geesh why dont you actually try before you say it doesnt fit LOL.
I have the exact intake as you. The hose coupler is bigger but when you tighten on the coupler it shrinks down perfectly. It doesnt bind or bunch up to cause a leak. It will seal just fine and will not leak. You dont want a pipe the size of the TB or it will reduce the air flow. A step down coupler might be better but trust me when I say it will work perfectly if you just tighten it down. Take a look at mine again and you will see.
That template is for that intake as well.
This intake is the exact design of the Place Racing intake. They look identical.
When modding you have to remember that not everything is going to fit just like you think it will.
Good luck.
Old Jul 12, 2004 | 02:12 PM
KLoWnPR109's Avatar
I think you should just stick with the stock airbox
Old Jul 12, 2004 | 03:43 PM
YoU CaNt SeE mE
stock air box =
CAI =
Old Jul 12, 2004 | 04:02 PM
KLoWnPR109's Avatar
Well it fits perfect, no holes to be drilled, you dont have to worry about hydrolocking
Old Jul 12, 2004 | 05:01 PM
internetautomar's Avatar
mod or sell?
but we'll see if after I'm done with the brakes and suspension mods if I keep the car I'll do a CAI and y-pipe
Old Jul 12, 2004 | 07:46 PM
MrGone's Avatar
I wish I felt gains from mine
Old Jul 13, 2004 | 12:35 AM
Cheocwa's Avatar
I don't get it. Why did you not do more resarch before you bought it. I love mine, it fit perfectly and I have installed two of them. My friends went in perfectly as well. As for the rain, I have not had problems yet and I do not think I ever will.
Old Jul 20, 2004 | 08:45 PM
thumpyls's Avatar
how about the guys w/ the vg?
Old Jul 20, 2004 | 08:50 PM
xMaxed90x's Avatar
For the guys w\ tha vg's buy a Place Racing CAI and a AEM air aybass valve = yummy goodness... i just put it in 2day no problem i will post pics 2 morrow!!!
Old Jul 20, 2004 | 08:53 PM
thumpyls's Avatar
unfortunately im on a college budget..post prices.theirs alot of people who do the 93 accord.for less than 50
Old Jul 20, 2004 | 10:38 PM
xMaxed90x's Avatar
I am on tha college budget as well but the 300+ for the intake and AEM Air Bypass Value fixed ma gas guzzlin woes and since i compute every time I drive now i save money!!!!!
Old Jul 21, 2004 | 08:27 AM
thumpyls's Avatar
300 is a good price for performance..its great quality also,and designed for ur car.i just cant see myself doing this mod unless i see a car physically w/ the cai and compare it to my neighbors 93 cai hybrid.50 or 300
Old Jul 21, 2004 | 10:50 PM
bobbydigital450's Avatar
dont want to be the guy that posts the stuff from ebay and ****es everyone off, but since their in an abundance and its so readily available... Is the CAI you all are refering to?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7911439165
I was gnna do this mod a while ago, but never got around to it and lost the ebay link, if someone could let me know if this is the right one or not, it would be appreciated.
Old Jul 22, 2004 | 07:34 AM
Michael's Avatar
Back in a 3rd Gen.
Yeah basically...I got mine from liveonspeed though. The only thing I see different on that one you listed is that it has a really cheap filter with a screen on then end of it. Do no use that filter if you get it. A screen will not keep dirt and dust out of your engine.
Maxima_Joe
Nov 25, 2015 08:19 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
BGTONIO1991
Aug 11, 2015 07:38 AM
