Sluggish, with wierd revving sound on acceleration
Old Aug 4, 2004 | 03:27 PM
broncoguy's Avatar
The car has been running very sluggish lately, and makes a wierd revving sound when shifting between gears (auto). RPM guage doesn't go way up like the tranny is slipping, seems to shift at the correct points, but it is the most sluggish at the shift points. Tranny was rebuilt about a year ago, fluid level is good. The only major thing I have done lately is the manifold studs. Anyone have any thoughts?
Old Aug 4, 2004 | 03:37 PM
smokyman13
maybe bad knock sensor?
Old Aug 5, 2004 | 07:33 AM
broncoguy's Avatar
I've seen a few posts recently about the knock sensor on the VG- First off, does the VG actually have a knock sensor? All of the posts I see on here are for the VE sensor.
Old Aug 5, 2004 | 05:06 PM
internetautomar's Avatar
mod or sell?
yes it has a knock sensor, but it's knock sensor doesn't have the heat soak problem and is MUCH easier to replace
Old Sep 21, 2004 | 01:56 PM
broncoguy's Avatar
OK, so looking through the posts that I found while doing a SEARCH (hooray, it works!!), I have only been able to determine that the VG knock sensor is located on the block, somewhere by or under the rear exhaust manifold. (Information that would have been good to have 2 months ago when I was changing manifold studs, but...)
Most people say that the sensor is not as big of a deal on th VG as it is on the VE. But, does it cause the same problems when it goes bad, and can it be checked the same way as the VE?
I have several things going on with my car at the moment, so I'm trying to narrow all the probs down.
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
